Home » Language IDEs » Java Development Tools (JDT) » Call hierarchy mislead
Call hierarchy mislead [message #148728] Mon, 15 March 2004 12:10 Go to next message
Originally posted by: arnout.standaert.n-o-s-p-a-m.cit.kuleuven.ac.be
Hi group,
I'm using build I20040226 currently for my development work (it seems
I20040310 has some serious issues with debugging, so I reverted). I
frequently use the Call Hierarchy command to check program flow.
Now, the problem: when a certain method A is mentioned in the javadoc
comments of another method B (for example, in a {@link} tag), then
Call Hierarchy interprets this as if method B actually calls method
A. This is, of course, incorrect.
Can anyone confirm this? Should I file a bug report for this?
Thanks in advance,
Wald
Re: Call hierarchy mislead [message #148738 is a reply to message #148728] Mon, 15 March 2004 13:01 Go to previous messageGo to next message
Originally posted by: linnet.nospam.users.sourceforge.net
Hi Wald,
Yes please. I think this is a bug. I don't think it is interesting to
see references from documentation when following code flow. If that is
needed, the ordinary search should be used instead (which generates the
same result).
Please enter "[call hierarchy]" as part of the subject.
Jesper
Wald wrote:
> Hi group,
> Thanks in advance,
> Wald
Re: Call hierarchy mislead [message #148777 is a reply to message #148738] Mon, 15 March 2004 15:23 Go to previous message
Originally posted by: arnout.standaert.n-o_s-p-a-m.cit.kuleuven.ac.be
Jesper Kamstrup Linnet <linnet@nospam.users.sourceforge.net> wrote:
> Hi Wald,
> same result).
Filed bug number 54892.
Thanks for the response,
Wald
Previous Topic:Eclipse 3.0M7 (Solaris 8/Motif) crashes after right click
Next Topic:Exception running eclipse
Current Time: Sun Jun 08 14:24:02 EDT 2025
Powered by FUDForum. Page generated in 0.03954 seconds
