Home » Modeling » GMF (Graphical Modeling Framework) » Problem while running the gmf digram plugin from an RCP application.
Problem while running the gmf digram plugin from an RCP application. [message #148664] Fri, 31 August 2007 07:49
Originally posted by: biju_gopinathan.rediffmail.com
Hi friends,
I have created a gmf digram plugin, and is able to run it
alone successfully.
But as I tried to run my digram plugin from an rcp
application, it works in an unexpected manner. That is:
1. I am able to create the digram file, but not able to drag n drop
items from pallet. When I try to drop it shows 'No' symbol.
2. And if I create Items on canvas using the pop up menu, some figures
get multiplied(if I add one, it shows around 500 figures in the canvas),
and on adding some figures it throws an StackOverflow Exception.
Any Idea.. on the above problem and on how can I crate my
digram file from an rcp application..?
Thanks and regards Biju
Previous Topic:How To Duplicate An EList
Next Topic:IHow can I create a Properties tab (as Topcased UML) in my GMF editor?
Current Time: Fri Jul 18 19:10:38 EDT 2025
Powered by FUDForum. Page generated in 0.02465 seconds
