Home » Eclipse Projects » GEF » Correct way to set initial node size?
Correct way to set initial node size? [message #148559] Wed, 25 August 2004 09:37 Go to next message
Originally posted by: aprice.nospam.versata.com
Good Day,
I've been unable to fathom the correct way to specify the initial size for a
new node (created by click on palette tool, click at target location).
I'm using a subclass of XYLayoutEditPolicy, whose (inherited)
getConstraintFor(Request) implementation returns an empty Rectangle at the
target point if the Request's size property is null; according to the docs
the 'emptiness' signifies that that figures's preferred size is to be used.
It's not clear to me whether this implies that the framework will somehow
apply the preferred size for the corresponding figure, but it certainly
doesn't seem to behave like that. The only way seems to be to set an
explicit size in the request object, which seems odd because I'd have
thought the obvious place to specify the default size is via
Figure.getPreferredSize() - the problem is that one doesn't have a figure
instance in the call to LayoutEditPolicy.getCreateCommand(CreateRequest).
Is there a recommended way to set an initial size?
Thanks in advance,
Adrian Price
Re: Correct way to set initial node size? [message #148576 is a reply to message #148559] Wed, 25 August 2004 10:22 Go to previous messageGo to next message
The size is determined by your model, not the figure. If you want it to be
the preferred size of the figure, you can represent this in your model by
using width/height of -1. The layout manager will then query the figure for
its preferred size at layout time. Otherwise, set it to whatever makes
sense for that model object.
"Adrian Price" <aprice@nospam.versata.com> wrote in message
news:cgi5sj$jjs$1@eclipse.org...
> Good Day,
a
used.
> Thanks in advance,
> Adrian Price
Re: Correct way to set initial node size? [message #149711 is a reply to message #148576] Thu, 26 August 2004 03:47 Go to previous message
Aaahh - makes perfect sense now you've pointed that out :-)
Thanks Randy!
best,
Adrian.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:cgi754$mfn$1@eclipse.org...
be
for
> > Good Day,
for
> a
the
docs
> used.
somehow
figure
> > Thanks in advance,
> > Adrian Price
Previous Topic:Ruler/Status bar feedback
Next Topic:GEF Viewer in Dialog
Current Time: Sun Aug 31 23:33:11 EDT 2025
Powered by FUDForum. Page generated in 0.03443 seconds
