Home » Eclipse Projects » Subversive » can't create patches anymore
can't create patches anymore [message #13849] Tue, 19 February 2008 17:18 Go to next message
since the version from February 14th I'm unable create patches, the
operation crashes/exists/quits with this message:
Create patch operation failed.
svn: Requested SVNAdmin functionality is not yet implemented
any Ideas? - I mean the message seems obvious but I'm just wondering
because it was working before...
thanks in advance
Ingo
Re: can't create patches anymore [message #13906 is a reply to message #13849] Tue, 04 March 2008 10:53 Go to previous messageGo to next message
Originally posted by: alexander.gurov.polarion.org
Dear Ingo,
The problem happens because you selected in preferences the SVN Kit 1.2.0
based connector which now is in "alpha-version" state. If you need to use
SVN 1.5 compatible connector please select native JavaHL 1.5.0 which is
much more stable at this moment.
Ingo Renner wrote:
> thanks in advance
> Ingo
Re: can't create patches anymore [message #14356 is a reply to message #13906] Tue, 04 March 2008 15:28 Go to previous message
Alexander Gurov wrote:
Hi Alexander,
> 1.2.0 based connector which now is in "alpha-version" state. If you need
> to use SVN 1.5 compatible connector please select native JavaHL 1.5.0
> which is much more stable at this moment.
does JavaHL work on Mac OS X, too?
thanks for the info
Ingo
Previous Topic:Can't diff between versions in branch
Next Topic:Find/Check problem
Current Time: Mon Jul 21 21:52:51 EDT 2025
Powered by FUDForum. Page generated in 0.06051 seconds
