| Ant script stalls [message #148386] |
Fri, 12 March 2004 15:44   |
Eclipse User  |
I'm using Eclipse 2 and Eclipse 3 (Tried M7 and M6, current=M6).
I have a simple build.xml file which simply seems to stall in the console.
In Eclipse 2, it gives me the following output:
Buildfile: c:\eclipse\workspace\SurveyApp\build.xml
Copy JSPs to Root:
     [copydir] DEPRECATED - The copydir task is deprecated.  Use copy
instead.
BUILD SUCCESSFUL
Total time: 781 milliseconds
In Eclipse 3, There is a new Console instance created each time I launch,
but nothing gets printed out, it just stays there for hours.  I can
terminate the console, but I still can't "build".
I looked at the \workspace\.metadata\.log file and did not see any note
about ant.  Is there something I'm missing?  Which log file should I be
looking at?
| Re: Ant script stalls [message #149061 is a reply to message #149054] |
Wed, 17 March 2004 14:26    |
Eclipse User  |
Check out the docs for the javac task:
http://ant.apache.org/manual/CoreTasks/javac.html
Basically you set the target attribute appropriately.
I believe you want to set your target to 1.1
We still should not be hanging and I will log a bug from this conversation
and look into the issue.
Thanks for you help,
Darins
"GaS" <gaseguin@cyberus.ca> wrote in message
news:c3a76p$k61$1@eclipse.org...
> WOUHOU!! it was using my JDK 1.2 setting.  I modified it to JDK 1.4 and it
> seams to work fine!  Must be a problem between ant 1.5 - jdk 1.2 and
> eclipse somewhere.
> Eclips loads in a JDK 1.4 JVM session
> Ant loads in a JDK 1.4 JVM session,
> but if I add a compile target, which JVM will be used to compile the
> application?
> How can I make sure that the JDK used to compile is 1.22, even when I use
> ANT?
> Darin Swanson wrote:
> > Thanks.
> > To check the JRE for the Ant build, open the External tools launch
> > configuration dialog and go to the Ant JRE tab for your launch
> > configuration.
> > Darins
> > news:c3a59o$i72$1@eclipse.org...
> > > Eclipse loads from jdk 1.4 (j2sdk1.4.2_04), My default JRE (under
> > > Installed JRE, the one with a checkbox) is 1.2.2 (version 17 I
believe)
> > > I'm not 100% sure which is used by ant, but in ant's Global Entries,
it
> > > uses JDK 1.4's tools.jar.
> > > > I need a few more details (sorry I should have asked before)
> > > > Are you launching the build in the same or separate VM from Eclipse?
> > > > What VM are you using?
> > > > Darins
| Re: Ant script stalls [message #149070 is a reply to message #149061] |
Wed, 17 March 2004 14:32   |
Eclipse User  |
Logged https://bugs.eclipse.org/bugs/show_bug.cgi?id=55140
Darins
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:c3a88i$lbt$1@eclipse.org...
> Darins
it
> > eclipse somewhere.
> > application?
use
> > ANT?
> > > Thanks.
> > > configuration.
> > > Darins
> believe)
> it
Eclipse?
> > > > > Darins
| Re: Ant script stalls [message #149087 is a reply to message #149070] |
Eclipse User  |
Thanks Again
> Darins
> > Darins
> it
> > > eclipse somewhere.
> > > application?
> use
> > > ANT?
> > > > Thanks.
> > > > configuration.
> > > > Darins
> > believe)
> > it
> Eclipse?
> > > > > > Darins
FUDForum. Page generated in 0.13084 seconds
