Home » Language IDEs » Java Development Tools (JDT) » Ant script stalls
Ant script stalls [message #148386] Fri, 12 March 2004 15:44 Go to next message
I'm using Eclipse 2 and Eclipse 3 (Tried M7 and M6, current=M6).
I have a simple build.xml file which simply seems to stall in the console.
In Eclipse 2, it gives me the following output:
Buildfile: c:\eclipse\workspace\SurveyApp\build.xml
Copy JSPs to Root:
[copydir] DEPRECATED - The copydir task is deprecated. Use copy
instead.
BUILD SUCCESSFUL
Total time: 781 milliseconds
In Eclipse 3, There is a new Console instance created each time I launch,
but nothing gets printed out, it just stays there for hours. I can
terminate the console, but I still can't "build".
I looked at the \workspace\.metadata\.log file and did not see any note
about ant. Is there something I'm missing? Which log file should I be
looking at?
Re: Ant script stalls [message #148402 is a reply to message #148386] Fri, 12 March 2004 16:19 Go to previous messageGo to next message
Can you provide the build file either here or in a bug report?
Darins
"GaS" <gaseguin@cyberus.ca> wrote in message
news:c2t7fv$3qe$1@eclipse.org...
> Copy JSPs to Root:
> instead.
> BUILD SUCCESSFUL
> looking at?
Re: Ant script stalls [message #148974 is a reply to message #148402] Wed, 17 March 2004 08:39 Go to previous messageGo to next message
Here it is:
<?xml version="1.0" encoding="UTF-8" ?>
<project name="Build Survey" default="Main Survey Build">
<property name="bin" location="WEB-INF/classes" />
<property name="src" location="WEB-INF/src" />
<property name="srcLibs" location="lib" />
<property name="serverBin" location="J:/Randy/CSIM/classes" />
<property name="marsHTDocs" location="J:/Randy/CSIM/htdocs" />
<property name="JSPDir" location="${src}/ccsb/scs/JSP" />
<property name="root" location="." />
<property name="build.compiler"
value="org.eclipse.jdt.core.JDTCompilerAdapter" />
<!-- Announcement Variables -->
<property name="gaPkg" value="/ccsb/scs/ga"/>
<target name="Main Survey Build" >
<echo message="Built."></echo>
</target>
<target name="Copy JSPs to Root">
<copydir src="${JSPDir}"
dest="${root}"/>
</target>
<target name="MARS: Copy GA">
<copy todir="${marsHTDocs}">
<fileset dir="${JSPDir}" >
<include name="**/GA*"/>
</fileset>
</copy>
<copy todir="${serverBin}${gaPkg}">
<fileset dir="${src}${gaPkg}" >
</fileset>
</copy>
</target>
</project>
> Darins
> > Buildfile: c:eclipseworkspaceSurveyAppbuild.xml
> > Copy JSPs to Root:
> > instead.
> > BUILD SUCCESSFUL
> > I looked at the workspace.metadata.log file and did not see any note
> > looking at?
Re: Ant script stalls [message #149010 is a reply to message #148974] Wed, 17 March 2004 12:40 Go to previous messageGo to next message
I need a few more details (sorry I should have asked before)
Are you launching the build in the same or separate VM from Eclipse?
What VM are you using?
Darins
news:c39kek$r10$1@eclipse.org...
> Here it is:
> </target>
> dest="${root}"/>
> </target>
> </fileset>
> </copy>
> </fileset>
> </copy>
> </target>
> </project>
> > Darins
console.
> > > Copy JSPs to Root:
> > > instead.
> > > BUILD SUCCESSFUL
launch,
be
> > > looking at?
Re: Ant script stalls [message #149031 is a reply to message #149010] Wed, 17 March 2004 13:27 Go to previous messageGo to next message
Eclipse loads from jdk 1.4 (j2sdk1.4.2_04), My default JRE (under
Installed JRE, the one with a checkbox) is 1.2.2 (version 17 I believe)
I'm not 100% sure which is used by ant, but in ant's Global Entries, it
uses JDK 1.4's tools.jar.
> Darins
Re: Ant script stalls [message #149046 is a reply to message #149031] Wed, 17 March 2004 13:49 Go to previous messageGo to next message
Thanks.
To check the JRE for the Ant build, open the External tools launch
configuration dialog and go to the Ant JRE tab for your launch
configuration.
Darins
news:c3a59o$i72$1@eclipse.org...
> > Darins
Re: Ant script stalls [message #149054 is a reply to message #149046] Wed, 17 March 2004 13:59 Go to previous messageGo to next message
WOUHOU!! it was using my JDK 1.2 setting. I modified it to JDK 1.4 and it
seams to work fine! Must be a problem between ant 1.5 - jdk 1.2 and
eclipse somewhere.
Eclips loads in a JDK 1.4 JVM session
Ant loads in a JDK 1.4 JVM session,
but if I add a compile target, which JVM will be used to compile the
application?
How can I make sure that the JDK used to compile is 1.22, even when I use
ANT?
> Thanks.
> configuration.
> Darins
> > > Darins
Re: Ant script stalls [message #149061 is a reply to message #149054] Wed, 17 March 2004 14:26 Go to previous messageGo to next message
Check out the docs for the javac task:
http://ant.apache.org/manual/CoreTasks/javac.html
Basically you set the target attribute appropriately.
I believe you want to set your target to 1.1
We still should not be hanging and I will log a bug from this conversation
and look into the issue.
Thanks for you help,
Darins
news:c3a76p$k61$1@eclipse.org...
> eclipse somewhere.
> application?
> ANT?
> > Thanks.
> > configuration.
> > Darins
believe)
it
> > > > Darins
Re: Ant script stalls [message #149070 is a reply to message #149061] Wed, 17 March 2004 14:32 Go to previous message
Logged https://bugs.eclipse.org/bugs/show_bug.cgi?id=55140
Darins
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:c3a88i$lbt$1@eclipse.org...
> Darins
it
> > eclipse somewhere.
> > application?
use
> > ANT?
> > > Thanks.
> > > configuration.
> > > Darins
> believe)
> it
Eclipse?
> > > > > Darins
Re: Ant script stalls [message #149087 is a reply to message #149070] Wed, 17 March 2004 14:32 Go to previous message
Thanks Again
> Darins
> > Darins
> it
> > > eclipse somewhere.
> > > application?
> use
> > > ANT?
> > > > Thanks.
> > > > configuration.
> > > > Darins
> > believe)
> > it
> Eclipse?
> > > > > > Darins
Previous Topic:Ant tasks and types have leading / in M7
Next Topic:JUnit: template for run/debug configurations
Current Time: Mon Jul 14 06:41:40 EDT 2025
Powered by FUDForum. Page generated in 0.07592 seconds
