using blackbox in a qvt transformation called by java [message #1017984] |
Tue, 12 March 2013 18:52  |
As mentioned in the title, I use a blackbox in my qvto transformation. It works fine when I launch the transformation manually, but when I use java to execute the transformation it fails. The obtained message sais:
Compilation errors found in unit 'platform:/plugin/org.qvt.transformation/model/Transformation.qvto'
what should I modify to fix the problem? dependencies?
I would appreciate your help, thanx a lot
Re: using blackbox in a qvt transformation called by java [message #1018395 is a reply to message #1017984] |
Wed, 13 March 2013 15:00  |
Please use the qvto newsgroup for qvto discussion.
It would be much easier to hel;p if you told us what the errors are!
Ed Willink
On 12/03/2013 22:52, chadi assem wrote:
> sais:
FUDForum. Page generated in 0.34016 seconds
