Home » Language IDEs » C / C++ IDE (CDT) » Does the stable release work with Eclipse 3.1?
Does the stable release work with Eclipse 3.1? [message #148201] Tue, 05 July 2005 12:51 Go to next message
Originally posted by: matthias.digitalraidREMOVETHIS.com
I consider migrating to Eclipse + CDT. I saw the announcement of a CDT
release exclusively built for Eclipse 3.1, but if I have the choice, I'd
rather go with the stable release, which was built for Eclipse 3.0x and
use it with 3.1, if that's possible at all. Is it?
Matthias
Re: Does the stable release work with Eclipse 3.1? [message #148205 is a reply to message #148201] Tue, 05 July 2005 14:09 Go to previous messageGo to next message
Originally posted by: plankton.softwitch.net
as far as I know, CDT 3.0x works on only eclipse 3.1
and It looks work well for cygwin.
I think nobody will relrease it for eclipse 3.0x.
CDT has great improvement in 3.0. so you'd be better use eclipse 3.1 and
CDT 3.0 RC.
in C/C++ development, there are few differences in eclipse 3.0x and 3.1
so, don't worry. just try it. if you have problem with this. post that
to here. you have us :)
Matthias Kaeppler wrote:
> Matthias
Re: Does the stable release work with Eclipse 3.1? [message #148255 is a reply to message #148205] Wed, 06 July 2005 05:27 Go to previous messageGo to next message
Originally posted by: hibou.bonbon.net
I have eclipse 3.0.1 and I have tested the CDT3.0 RC1 : I confirm that
they are quite incompatible : some java class where missing to make the
cdt plugin work properly.
> CDT 3.0 RC.
>> I'd rather go with the stable release, which was built for Eclipse
>> 3.0x and use it with 3.1, if that's possible at all. Is it?
>> Regards,
>> Matthias
Re: Does the stable release work with Eclipse 3.1? [message #148257 is a reply to message #148255] Wed, 06 July 2005 05:24 Go to previous messageGo to next message
>> CDT 3.0 RC.
>>>Hi,
>>>Regards,
>>>Matthias
I think, he asked about running CDT 2.x with Eclipse 3.1. I must say i'm
not sure if this runs or not.
But as far as i know, you can use the update manager (help->software
updates->find and install) to try to download and install CDT 2.x. So if
this functions, there should exist no problems.
Marcus
Re: Does the stable release work with Eclipse 3.1? [message #148263 is a reply to message #148257] Wed, 06 July 2005 05:48 Go to previous message
That's right, that's what I meant. But I have installed 3.0 already,
testing it right now. As I supposed, it has a lot of serious bugs, the
indexer and content assist don't work at all. Everything CTRL-leftclick
does is displaying an "operation in progress" dialog. Then nothing
happens. Triggering CTRL-space on a hyperlink always causes a
NullPointerException (displayed in the statusbar). Also the . -> ::
triggers don't work, or it just doesn't offer any completions because
the indexer is broken.
By the way, if I want to file a bug in Bugzilla, how can I see if it
hasn't already been reported, without digging through every single
report which was filed in the last X months?
Matthias
Previous Topic:No console output Eclipse 3.1/CDT 3.0/Cygwin
Next Topic:Code templates
Current Time: Tue Jul 15 04:28:35 EDT 2025
Powered by FUDForum. Page generated in 0.05528 seconds
