Home » Modeling » GMF (Graphical Modeling Framework) » Two label layout in a Rectangle
Two label layout in a Rectangle [message #148101] Tue, 28 August 2007 10:20 Go to next message
I'm attemping to lay out two labels in a Rectangle like so:
______________
I I
I Label1 I
I Label2 I
I____________ I
so that they stay centred.
I can do it easily for a single label using a Stack Layout
but for two or more, they simply lay over each other.
Flow Layout doesn't seem to help either as it lays them to
the Left hand side, even when setting Major and Minor
Alignment to CENTER.
I've also tried using two contained rectangles, but no luck.
Can anyone advise on this before I go mad?!
Andy
Re: Two label layout in a Rectangle [message #148126 is a reply to message #148101] Wed, 29 August 2007 04:17 Go to previous messageGo to next message
Try using a GridLayout( 1 column) for the parent Rectangle and
GridlayoutData for each label...
ase a écrit :
> Hello,
> ______________
> I I
> I Label1 I
> I Label2 I
> I____________ I
> Andy
Re: Two label layout in a Rectangle [message #148510 is a reply to message #148126] Thu, 30 August 2007 06:29 Go to previous messageGo to next message
I've tried that now - see attached gmfgraph and result,
but the result is left hand placement of the labels.
Have I got the structure right?
Any other suggestions welcome!
Andy
"Gilles Cannenterre" <gilles.cannenterre@anyware-tech.com> wrote in message
news:fb3a2l$9ie$1@build.eclipse.org...
> ase a
  • Attachment: gmfgraph.jpg
    (Size: 17.39KB, Downloaded 118 times)
  • Attachment: result.jpg
    (Size: 2.80KB, Downloaded 108 times)
Re: Two label layout in a Rectangle [message #148524 is a reply to message #148510] Thu, 30 August 2007 07:22 Go to previous messageGo to next message
Hello ase,
For each of the grid layout data set
Grab excess horizontal space : true
Horizontal alignement : CENTER
it should work...
> Andy
>> ase a écrit :
>>> Hello,
>>> ______________
>>> I I
>>> I Label1 I
>>> I Label2 I
>>> I____________ I
>>> Thanks,
>>> Andy
Re: Two label layout in a Rectangle [message #148580 is a reply to message #148524] Thu, 30 August 2007 11:25 Go to previous message
Hi Giles,
That does seem to work. Although now I get the labels centred but
towards the top of the rectangle. I've tried setting grab excess vertical
space: true but no effect. Any thoughts?
Andy
news:fb699p$fmc$1@build.eclipse.org...
> Hello ase,
> it should work...
> ase a
Previous Topic:Adding EStructuralfeature
Next Topic:Localization of GMF editors
Current Time: Wed Jul 23 01:18:18 EDT 2025
Powered by FUDForum. Page generated in 0.04070 seconds
