Home » Archived » BIRT » Headed paper
Headed paper [message #148077] Mon, 27 March 2006 03:43 Go to next message
Hi.
I would like to include the company logo, heading, etc, as the master
page header of the report. The company logo is made of simple text
elements with different fonts, sizes and colors. I can apply the fonts
and colors without problems, however I can't position the elements with
the desired spacing, for example using a grid layout the spacing between
rows is excessive. It is not possible to specify a negative margin
value, nor I can't find how to override the spacing. Setting a row
height smaller than the computed height has no effects.
I can't even find how to export the report over an existing pdf document
(or include the pdf document as the background of all pages). This would
solve the problem as I'm already doing this with iText.
How do you handle headed paper with BIRT ?
Bye
Re: Headed paper [message #148090 is a reply to message #148077] Mon, 27 March 2006 04:33 Go to previous messageGo to next message
Originally posted by: r.budner.abg.com.pl
Marco Maccaferri napisał(a):
> Hi.
> Bye
You can use a Text element. You will be able then to provide your own
piece of HTML. If I were you, I would prepare an image of company logo
and use Image element on the report.
Re: Headed paper [message #148425 is a reply to message #148090] Mon, 27 March 2006 07:12 Go to previous messageGo to next message
> piece of HTML.
Using the html text apparently works, at least in the designer preview.
However when the document is exported as PDF the output overlap other
elements (and seems that it can't embed the fonts). I think that the
engine can't calculate the sizes very well when the html code is used.
Yes, but what about the output resolution ? The logo I'm using now is
very simple, but more complex logos are rendering very badly using the
screen resolutions.
Bye
Re: Headed paper [message #148673 is a reply to message #148425] Mon, 27 March 2006 15:54 Go to previous message
hi. i had the same problem with overlappings between the headers and the
normal page when i've exported to pdf. the solution i've found is to
modify the dimensions of header/footer. for me it worked.
cristian
Previous Topic:Ho to show total pagenumber
Next Topic:DataSet using Java Classes
Current Time: Mon Jul 21 21:20:23 EDT 2025
Powered by FUDForum. Page generated in 0.40228 seconds
