Home » Language IDEs » Java Development Tools (JDT) » instance method references
instance method references [message #148069] Wed, 10 March 2004 12:01 Go to next message
Originally posted by: chrismo.clabs.org
If I have:
public class MyForm
private Label lblA;
private Label lblB;
and I want to do a Java Search for all calls to lblA.setText(), how do I
do this? The default behavior, if I cursor to an instance of
lblA.setText and do a Workspace References search (Ctrl+Shift+G),
Eclipse searches for all instances of Label.setText, which would include
lblA.setText _and_ lblB.setText, not to mention every other
Label.setText call in the entire codebase (or the entire class, which is
painful if I have 17 label instances in the one class).
I tried doing a search on MyForm.lblA.setText and MyForm.lblA.setText*,
but both searches returned nothing.
Is there a way to do what I need?
(3.0.M7)
Chris
http://clabs.org
Re: instance method references [message #148079 is a reply to message #148069] Wed, 10 March 2004 13:23 Go to previous messageGo to next message
Originally posted by: varavamu.yahoo.com
Chris Morris wrote:
> If I have:
> public class MyForm
> private Label lblA;
> private Label lblB;
> (3.0.M7)
Note sure if this is the right way to do it, but if you need a quick
workaround:
Create an inner class or an anonymous class when assigning
(instantiating) your label, and override the setText() method, and
search for references.
I agree that this would be a good idea for a plugin/feature.
HTH,
Vijay
Re: instance method references [message #148106 is a reply to message #148069] Wed, 10 March 2004 22:10 Go to previous message
Originally posted by: smesh.openrules.com
It's the text search what you are looking for.
Sam Mesh - http://openrules.com
Previous Topic:inheritance
Next Topic:how do I set an env.var OSX from within Eclipse
Current Time: Thu Jul 17 21:42:53 EDT 2025
Powered by FUDForum. Page generated in 0.07402 seconds
