Method reference chain [message #148055] |
Wed, 10 March 2004 10:34  |
Originally posted by: chrismo.clabs.org
I love how Eclipse can show me all method references for a given method
-- I'd really love to have a process where I feed in a method and
recursively work backwards up the call chain (and to top it off get a
dot [http://www.research.att.com/sw/tools/graphviz/] graph showing the
whole thing).
Is there anything along those lines out there in Eclipse (or outside
Eclipse) land? If not, how could I programmatically hook into Eclipse's
ability to get me method references?
Chris
http://clabs.org
Re: Method reference chain [message #148260 is a reply to message #148176] |
Fri, 12 March 2004 00:12  |
Originally posted by: linnet.nospam.users.sourceforge.net
Hi Chris,
I'll give it a thought over the weekend. Before you get your hopes up,
though, I'm not very focused on developing further on the external
plugin, so if something's coming out of this, it's most likely for the
internal Eclipse version (although as a new external plugin).
Jesper
Chris Morris wrote:
> Jesper Kamstrup Linnet wrote:
>> Hi Chris,
>> If you want it for 2.1.2, you can install the plugin from
>> http://eclipse-tools.sf.net/call-hierarchy (update site:
>> http://eclipse-tools.sf.net/updates). It is basically the same plugin
>> from before I integrated it into Eclipse.
> Okay -- I saw that plug-in before seeing the 3.0 functionality and
> wondered if they were the same.
> Any chance of adding a dot (graphviz)[1] interface on this same data?
> :-) That would really be great. Or maybe just an export to a .dot file?
> [1] http://www.research.att.com/sw/tools/graphviz/
FUDForum. Page generated in 0.04811 seconds
