Home » Archived » BIRT » Reports in Web page using PHP
Reports in Web page using PHP [message #148050] |
Sun, 26 March 2006 09:25  |
Hi everyone,
I'm trying to produce reports using a web page using PHP, for now I'm
running the first example found in the BIRT site
(http://www.eclipse.org/birt/phoenix/deploy/usingPHP.php). But it simple
don't run. I tried in IIS and now in Apache 2. PHP runs in my Apache 2
web server.
Does anyone have a link to a page with more detailed info or a simple
running example?
My code and the message I receive is is found bellow
Any help will be very appreciated
Thanks in advance
Jose
Message:
Warning: Cannot modify header information - headers already sent by
(output started at C:\Program Files\Apache
Group\Apache2\htdocs\PHPApache\testBirt.php:3) in C:\Program
Files\Apache Group\Apache2\htdocs\PHPApache\testBirt.php on line 8
Source Code:
<html>
<head>
$fname = "c:/temp/test.rptdesign";
// Redirect browser
$dest = "http://localhost:8080/birt-viewer/run?__report=";
$dest .= urlencode( realpath( $fname ) );
header("Location: $dest" );
<title>Untitled Document</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
</head>
<body>
</body>
</html>
Re: Reports in Web page using PHP [message #148070 is a reply to message #148060] |
Sun, 26 March 2006 20:15   |
I appreciate your help Bo.
I think I'm missing something here. After removing the html tags like
you suggested I still have errors in my web browser.
Now the error is :
The page cannot be found
The page you are looking for might have been removed, had its name
changed, or is temporarily unavailable.
etc...
Thing's look better though :)
I have PHP 5 installed and I know it's running through my apache 2 web
server.
Any suggestions?
Bo Ugljesic wrote:
> Hello José,
> Looks like you all ready sent the html header info. Try this without the
> html tags.
> <?php
> $fname = "new_report.rptdesign";
> $paramValue = "pdf";
> $dest = "http://localhost:8180/birt/run?__report=";
> $dest .= urlencode( $fname );
> $dest .= "&__format=" . urlencode( $paramValue );
> $dest .= "&p_host=localhost";
> $dest .= "&p_db=conetstaff.com";
> A better way is to use CURL that way you can hide the url info.
> <?php
> $ch = curl_init($dest);
> if (! $ch) {
> die( "Cannot allocate a new PHP-CURL handle" );
> curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
> curl_setopt($ch, CURLOPT_BINARYTRANSFER, 1);
> $data = curl_exec($ch);
> curl_close($ch);
> header("Content-type: application/pdf");
> print($data);
> I got the code to use CURL from a reportman user group on yahoo.
> Bo
> José Meireles wrote:
>> Hi everyone,
>> simple don't run. I tried in IIS and now in Apache 2. PHP runs in my
>> Apache 2 web server.
>> running example?
>> Thanks in advance
>> Jose
>> Message:
>> Source Code:
>> <html>
>> <head>
>> // Redirect browser
>> </head>
>> <body>
>> </body>
>> </html>
Re: Reports in Web page using PHP [message #148852 is a reply to message #148393] |
Tue, 28 March 2006 07:28   |
Hello Bo,
Just installed, configured and started Tomcat. I believe everything is
ok now. I hava web server (apache2) a app server (Tomcat), my PHP is
configured to work with apache (and php files run ok), all is set to
port 8080, but when I run my code there are still errors:
after my testBirt.php redirect the output to:
http://localhost:8080/birt-viewer/run?__report=c%3A%5Ctemp%5 Ctest.rptdesign
it says:
Something is wrong, no doubt about that... but what? any hints?
Thank you for you concern
Jose
Bo Ugljesic wrote:
> Hello José,
> To deploy the reports in a production environment you will need a java
> app server, like tomcat, jboss etc...
> http://www.eclipse.org/birt/phoenix/build/#j2ee
> http://www.eclipse.org/birt/phoenix/deploy/viewerSetup.php
> Bo
>> I did it, the problem might be that I have Apache 2installed instead
>> of Apache Tomcat... Is it possible?
>> Bo Ugljesic wrote:
>>> make sure you change the code for the location and port of your
>>> tomcat server
>>>> like you suggested I still have errors in my web browser.
>>>> Now the error is :
>>>> etc...
>>>> web server.
>>>> Any suggestions?
Re: Reports in Web page using PHP [message #149032 is a reply to message #148852] |
Tue, 28 March 2006 11:07  |
Originally posted by: service.altekweb.com
Hello José,
Try http://localhost:8080 , this should get the tomcat console.
From there you can go to manager console and view the birt application.
Click on it and try to run report.
Tomcat has nothing to do with your apache2 server it is a seperate
server that runs on a different port.
Bo
> Hello Bo,
> it says:
> Jose
Current Time: Fri Jul 18 00:35:34 EDT 2025
Powered by FUDForum. Page generated in 0.07857 seconds
