Home » Modeling » GMF (Graphical Modeling Framework) » make a node non-resizable + non-movable ?
make a node non-resizable + non-movable ? [message #148048] Tue, 28 August 2007 08:18 Go to next message
Originally posted by: NOSPAM.xyz.com
I am working on an application in which a lot of useful data
is represented by the exact sizes and relative locations of the nodes.
In some cases the size + location of a node of given type must
be frozen to indicate that this node is in certain state.
How can one do that?
On that node I installed
NonResizableEditPolicyEx
and I also return null from
getDragTacker()
This helped somewhat - now that node does not get selected when
I click on it with the SelectionTool.
However, if I drag a marquee around it it is still gets selected and can
be moved + resized by using the handles.
Any tips?
Theo
Re: make a node non-resizable + non-movable ? [message #148051 is a reply to message #148048] Tue, 28 August 2007 08:30 Go to previous messageGo to next message
Hi Theo,
You may return an unexecutable command instead of SetBoundsCommand from
the <>LayoutEditPolicy of its parent. Thus it will be possible to select
the node (e.g., to change its properties via the property sheet), but
any attempt to move it will fail.
Boris
> getDragTacker()
> Any tips?
> Theo
Re: make a node non-resizable + non-movable ? [message #148110 is a reply to message #148051] Tue, 28 August 2007 13:17 Go to previous messageGo to next message
Thanks for the quick reply Boris.
I just achieved something similar by overriding
public EditPolicy getPrimaryDragEditPolicy()
to return new UnmovableShapeEditPolicy();
In my case this seems a good way to go because I would like
to deny changing the colors, etc, via the prop. sheet.
Instead, the combination of fore- + background colors should indicate
the special state of this node. Sorry for missing this in my original post.
I would even like to remove the handles because they suggest
editing capabilities. Somehow they survive yet. So now
I am scrambling to find who shows the outline frame with the
handles around a selected node.
Theo
"Boris Blajer" <boris.blajer@borland.com> wrote in message
news:fb14hl$4q0$1@build.eclipse.org...
> Hi Theo,
> the node (e.g., to change its properties via the property sheet), but any
> Best regards,
> Boris
>> getDragTacker()
>> Any tips?
>> Theo
Re: make a node non-resizable + non-movable ? [message #148112 is a reply to message #148110] Tue, 28 August 2007 13:46 Go to previous messageGo to next message
Hi Theo,
Returning false from EditPart#isSelectable() method may help you get rid
of the handles.
Boris
> Cheers,
> Theo
>> Hi Theo,
>> Best regards,
>> Boris
>>> getDragTacker()
>>> Any tips?
>>> Theo
Re: make a node non-resizable + non-movable ? [message #148114 is a reply to message #148112] Tue, 28 August 2007 13:55 Go to previous message
Yes it does... Today is my lucky day....
MAny thanks
Theo
news:fb1n1f$sq3$1@build.eclipse.org...
> Hi Theo,
> of the handles.
> Best regards,
> Boris
>> post.
>> Cheers,
>> Theo
>>> Hi Theo,
>>> Best regards,
>>> Boris
>>>> getDragTacker()
>>>> can
>>>> Any tips?
>>>> Theo
Previous Topic:create a child element when an attribute of the parent is set ...
Next Topic:Multiple editors in one feature
Current Time: Sun Aug 31 23:43:10 EDT 2025
Powered by FUDForum. Page generated in 0.04314 seconds
