Home » Archived » BIRT » POJO Data Source / Session Object Access - Example Available
POJO Data Source / Session Object Access - Example Available [message #147993] Fri, 24 March 2006 18:57
All,
I have noticed a lot of questions about using POJO's as data sources. I
have created a very quick blog about how to use a POJO and also how to
use data from your application context. You can find the examples out
on the BirtWorld blog at http://birtworld.blogspot.com/
Scott Rosenbaum
Birt PMC
Previous Topic:problem with output in pdf
Next Topic:URL
Current Time: Thu Jul 24 01:07:34 EDT 2025
Powered by FUDForum. Page generated in 0.04218 seconds
