Home » Archived » XML Schema Definition (XSD) » Help: Simple example of parsing a ComplexType?
Help: Simple example of parsing a ComplexType? [message #13777] Mon, 17 March 2003 05:18 Go to next message
Originally posted by: john.infonomicon.com
Hello all,
I _think_ I understand the basics of using the Infoset, and I have read the
provided article and FAQ. However, I am still completely at a loss as to how
I would examine the contents of an <xs:complexType>. For example, if I have
an element that comprises four sub-elements derived from type <xs:string>,
how could I programmatically determine their restrictions/enumerations etc?
Does anyone have a simple code snippet/example which would illustrate usage?
Thanks in advance,
John.
Re: Help: Simple example of parsing a ComplexType? [message #13797 is a reply to message #13777] Mon, 17 March 2003 07:56 Go to previous messageGo to next message
John,
Here's snippet of code that does some of the things you mention:
void handle(XSDElementDeclaration xsdElementDeclaration)
XSDTypeDefinition xsdTypeDefinition =
xsdElementDeclaration.getTypeDefinition();
if (xsdTypeDefinition instanceof XSDSimpleTypeDefinition)
XSDSimpleTypeDefinition xsdSimpleTypeDefinition =
(XSDSimpleTypeDefinition)xsdTypeDefinition;
for (Iterator i = xsdSimpleTypeDefinition.getFacets().iterator();
i.hasNext(); )
XSDFacet xsdFacet = (XSDFacet)i.next();
if (xsdFacet instanceof XSDEnumerationFacet)
for (Iterator j =
((XSDEnumerationFacet)xsdFacet).getValue().iterator(); j.hasNext(); )
Object enumerator = j.next();
else if (xsdFacet instanceof XSDPatternFacet)
else
XSDComplexTypeDefinition xsdComplexTypeDefinition =
(XSDComplexTypeDefinition)xsdTypeDefinition;
switch (xsdComplexTypeDefinition.getContentTypeCategory().getValue( ))
case XSDContentTypeCategory.EMPTY:
break;
case XSDContentTypeCategory.SIMPLE:
(XSDSimpleTypeDefinition)xsdComplexTypeDefinition.getContent Type();
break;
case XSDContentTypeCategory.ELEMENT_ONLY:
case XSDContentTypeCategory.MIXED:
XSDParticle xsdParticle =
(XSDParticle)xsdComplexTypeDefinition.getContentType();
XSDTerm xsdTerm = xsdParticle.getTerm();
if (xsdTerm instanceof XSDModelGroup)
XSDModelGroup xsdModelGroup = (XSDModelGroup)xsdTerm;
for (Iterator i = xsdModelGroup.getParticles().iterator();
i.hasNext(); )
XSDParticle childXSDParticle = (XSDParticle)i.next();
else if (xsdTerm instanceof XSDElementDeclaration)
else if (xsdTerm instanceof XSDWildcard)
break;
It's an unfortunate fact of life that XML Schema is incredibly complicated...
John McDonnell wrote:
> Hello all,
> Thanks in advance,
> John.
Re: Help: Simple example of parsing a ComplexType? [message #13817 is a reply to message #13797] Mon, 17 March 2003 15:42 Go to previous message
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:3E75C602.77C8805A@ca.ibm.com...
> John,
Much goodness snipped!
complicated...
Thanks to Ed and his example, my problems are solved :). Though a little
knowledge is a dangerous thing, I think I feel an article coming on...
John.
Re: Help: Simple example of parsing a ComplexType? [message #566343 is a reply to message #13777] Mon, 17 March 2003 07:56 Go to previous message
John,
i.hasNext(); )
for (Iterator j =
else
break;
break;
i.hasNext(); )
break;
> Hello all,
> Thanks in advance,
> John.
Re: Help: Simple example of parsing a ComplexType? [message #566371 is a reply to message #13797] Mon, 17 March 2003 15:42 Go to previous message
> John,
complicated...
John.
Previous Topic:Help: Simple example of parsing a ComplexType?
Next Topic:Retrieving the line number from XSDDiagnostic
Current Time: Fri Jun 06 11:21:55 EDT 2025
Powered by FUDForum. Page generated in 0.34367 seconds
