Home » Modeling » GMF (Graphical Modeling Framework) » How to prevent user to drag a contained element
How to prevent user to drag a contained element [message #147910] Mon, 27 August 2007 09:44 Go to next message
I've got an container element (A) and a contained element (B). A contains B
in a flow layout. As A and B almost have the same size, when I click on A
the editor selects B. I would like to prevent the selection of B, every
click should select the container element A.
I guess it has something to do with an Edit Policy but I can't find it, any
clue ?
Cédric
Re: How to prevent user to drag a contained element [message #147918 is a reply to message #147910] Mon, 27 August 2007 10:00 Go to previous messageGo to next message
I found the solution myself : overriding getDragTracker in the B edit part:
public DragTracker getDragTracker(Request request) {
return getParent().getDragTracker(request);
Keep up the good work !
Cédric
Cédric Brun wrote:
> B in a flow layout. As A and B almost have the same size, when I click on
> A the editor selects B. I would like to prevent the selection of B, every
> any clue ?
> Cédric
Re: How to prevent user to drag a contained element [message #147945 is a reply to message #147918] Mon, 27 August 2007 11:03 Go to previous messageGo to next message
Let's re-open the issue, now I would like the B element to be ignored by the
tools, I'm being prevented to create connection when I hover the B
(contained in A) but the connection is correct from an A element, and as
the A element have no label I can't select it.
Where do GMF find the edit part starting from the mouse position ? I could
override this behavior no ?
> part:
> @Override
> Cédric
> Cédric Brun wrote:
>> any clue ?
>> Thanks,
>> Cédric
Re: How to prevent user to drag a contained element [message #147952 is a reply to message #147945] Mon, 27 August 2007 11:08 Go to previous messageGo to next message
I'll answer myself another time :)
removing all the code in createDefaultEditPolicies of B and only A will
answer the requests !
> the tools, I'm being prevented to create connection when I hover the B
>> part:
>> @Override
>> Cédric
>> Cédric Brun wrote:
>>> Hi,
>>> contains B in a flow layout. As A and B almost have the same size, when
>>> I click on A the editor selects B. I would like to prevent the selection
>>> of B, every click should select the container element A.
>>> any clue ?
>>> Thanks,
>>> Cédric
Re: How to prevent user to drag a contained element [message #147959 is a reply to message #147945] Mon, 27 August 2007 11:12 Go to previous message
Hi Cédric,
Take a look at EditPart#getTargetEditPart(),
EditPart#understandsRequest(), EditPart#performRequest(). You may also
need to delegate EditPart#showSourceFeedback(),
EditPart#showTargetFeedback() and the associated erase<>Feedback()
methods as well.
Boris
>> part:
>> @Override
>> Cédric
>> Cédric Brun wrote:
>>> Hi,
>>> any clue ?
>>> Thanks,
>>> Cédric
Previous Topic:figures with draw2D
Next Topic:Feature Seq Initializer doesn't work good for me
Current Time: Wed May 07 19:19:45 EDT 2025
Powered by FUDForum. Page generated in 0.03518 seconds
