Home » Language IDEs » Java Development Tools (JDT) » Problem runnning ant 1.6 with eclipse 2.1.2
Problem runnning ant 1.6 with eclipse 2.1.2 [message #147889] Tue, 09 March 2004 04:05 Go to next message
Originally posted by: djeanprost.NOSPAMsofaxis.com
Im' trying to run an ant script with eclipse. The script works well in dos
mode, but in eclipse I get a NoSucheMethodError
Can anyone help me ?
Dom
Apache Ant version 1.6.0 compiled on December 18 2003
Buildfile: W:\root\JAR_common_util\build.xml
parsing buildfile W:\root\JAR_common_util\build.xml with URI =
file:///W:/root/JAR_common_util/build.xml
Project base dir set to: C:\
Importing file c:\classes\default.xml from W:\root\JAR_common_util\build.xml
parsing buildfile C:\classes\default.xml with URI =
file:///C:/classes/default.xml
Arguments: -verbose -Dorg.eclipse.ui.externaltools.ATTR_ANT_PROCESS_ID=10788
22678982
Build sequence for target `build' is [pre_init, init, prepare, ejbdoclet,
compile, build]
Complete build sequence is [pre_init, init, prepare, ejbdoclet, compile,
build, compile_test, getGUI, checkVersion, version, getLastVersion, test,
getTaggedVersion, compile_for_release, release, ]
pre_init:
init:
[property] Loading C:\classes\ant.properties
[property] Loading Environment env.
[copy] C:\classes\jars\common_util.jar omitted as
C:\temp\jarsCopy\common_util.jar is up to date.
[copy] C:\classes\jars\version.jar omitted as C:\temp\jarsCopy\version.jar
is up to date.
[delete] Deleting directory C:\temp\ant\build
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\ejb\EJBHomeHolder .class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\ejb\EJBUtils.clas s
[delete] Deleting directory C:\temp\ant\build\classes\com\dexia\common\ejb
[delete] Deleting C:\temp\ant\build\classes\com\dexia\common\ged\GED.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\ged\GEDDocument.c lass
[delete] Deleting directory C:\temp\ant\build\classes\com\dexia\common\ged
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\io\CustomizedBase 64Decoder.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\io\CustomizedBase 64Encoder.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\io\FileUtils.clas s
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\io\StreamUtils.cl ass
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\io\WeakFile.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\io\WeakFileInputS tream.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\io\XORInputStream .class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\io\XOROutputStrea m.class
[delete] Deleting directory C:\temp\ant\build\classes\com\dexia\common\io
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\jndi\AbstractServ iceEJB.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\jndi\AbstractServ iceJMS.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\jndi\AbstractServ iceLocator.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\jndi\AbstractServ iceWeb.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\jndi\EnvironmentE ntriesHolder.cla
ss
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\jndi\ServiceEJB.c lass
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\jndi\ServiceJMS.c lass
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\jndi\ServiceLocat or.class
[delete] Deleting directory C:\temp\ant\build\classes\com\dexia\common\jndi
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\lang\ChainedExcep tion.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\lang\ChainedRunti meException.clas
s
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\lang\FieldExcepti on.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\lang\MultiFieldEx ception.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\lang\ObjectDoesNo tExistException.
class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\lang\PKIllegalSta teException.clas
s
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\lang\SystemExcept ion.class
[delete] Deleting directory C:\temp\ant\build\classes\com\dexia\common\lang
[delete] Deleting C:\temp\ant\build\classes\com\dexia\common\mail\Fax.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\mail\Mail$Attache dFile.class
[delete] Deleting C:\temp\ant\build\classes\com\dexia\common\mail\Mail.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\mail\MailProducer $1.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\mail\MailProducer $2.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\mail\MailProducer .class
[delete] Deleting directory C:\temp\ant\build\classes\com\dexia\common\mail
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\security\Security .class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\servlet\download\ ByteArrayDownloa
dJob.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\servlet\download\ ContentDownloadJ
ob.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\servlet\download\ DownloadJob.clas
s
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\servlet\download\ DownloadManager.
class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\servlet\download\ DownloadResponse
Code.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\servlet\download\ DownloadServlet.
class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\servlet\download\ EasyDownloadServ
let.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\servlet\download\ FileDownloadJob.
class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\servlet\download\ GenericDownloade
r.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\servlet\download\ InputStreamDownl
oadJob.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\servlet\download\ MergedRTFDownloa
dJob.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\servlet\ServletUt ils.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\servlet\SessionCo nsign.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\servlet\upload\Up loadedFile.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\servlet\upload\Up loadManager.clas
s
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\servlet\upload\Up loadRequest.clas
s
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\servlet\upload\Up loadResult.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\servlet\upload\Up loadServlet.clas
s
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\servlet\upload\Up loadWrapper.clas
s
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\servlet\WebFile.c lass
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\sql\DataSourceHol der.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\sql\MSSQLError.cl ass
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\sql\SecureDataSou rce.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\sql\SmartResultSe t.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\sql\SQLUtils.clas s
[delete] Deleting directory C:\temp\ant\build\classes\com\dexia\common\sql
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\AbstractRTFT ableModel.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\AbstractStat eHolder.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\AdresseForma ter.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\AppServerLog ger$1.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\AppServerLog ger$LoggerImpl.c
lass
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\AppServerLog ger.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\Calculatrice Montant.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\CharArray.cl ass
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\CharArrayNod e.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\CharUtils.cl ass
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\CollectionFa ctory$1.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\CollectionFa ctory$2.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\CollectionFa ctory$3.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\CollectionFa ctory$4.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\CollectionFa ctory$5.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\CollectionFa ctory$6.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\CollectionFa ctory.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\Consign.clas s
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\csv\Abstract CsvModel.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\csv\CsvFileB uilder.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\dao\Abstract DAO.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\dao\DAO.clas s
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\DateFormater .class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\DateUtils.cl ass
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\DebugUtils.c lass
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\Delai$TypeUn ite.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\Delai.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\Dictionnaire $1.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\Dictionnaire .class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\Dictionnaire Francais$EntreeD
ictionnaireFrancais.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\Dictionnaire Francais.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\Displayable. class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\EntreeDictio nnaire.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\Enumerated.c lass
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\EtatCivilFor mater.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\FakeDataSour ce.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\FileUtils.cl ass
[delete] Deleting C:\temp\ant\build\classes\com\dexia\common\util\GUID.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\GUIDHelper.c lass
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\Historique$E ntry.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\Historique.c lass
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\HtmlConverte r.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\Identifiable .class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\Intervalle.c lass
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\LazyLoadingP ersistent$1.clas
s
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\LazyLoadingP ersistent$Abstra
ctPersistentContainer.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\LazyLoadingP ersistent$Persis
tentAttribute.class
[delete] Deleting
tentCollection.class
[delete] Deleting
tentMap.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\LazyLoadingP ersistent.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\Logger.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\MainArgument sHolder.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\MainNode.cla ss
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\MimeUtils.cl ass
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\MiniGED$1.cl ass
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\MiniGED$Mini GEDDocument.clas
s
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\MiniGED.clas s
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\MRUCache$1.c lass
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\MRUCache$MRU Item.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\MRUCache.cla ss
[delete] Deleting C:\temp\ant\build\classes\com\dexia\common\util\Node.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\pdf\FDFMerge r.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\pdf\FieldDef .class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\pdf\Merger.c lass
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\pdf\PDFMerge r.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\pdf\PDFUtils .class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\pdf\ValueFie ldDef.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\Persistent.c lass
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\PersistentCo ntainer.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\PersistentSt ate.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\PrimaryKey.c lass
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\PrivateAcces s.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\Registry.cla ss
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\RegistryExce ption.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\rtf\Abstract RTFTableModel.cl
ass
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\rtf\RTFConve rter.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\rtf\RTFFlow. class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\rtf\RTFifiab le.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\rtf\RTFParag raph.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\rtf\RTFTable .class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\rtf\RTFUtils .class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\RTFConverter .class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\RTFTable.cla ss
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\SmartCollect ion.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\SmartCollect ions.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\SplitNode.cl ass
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\StringNode.c lass
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\StringUtils. class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\TelephoneFor matter.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\URLBuilder.c lass
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\Utils.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\xml\StreamTr ansformer.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\xml\XMLDocum ent.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\xml\XMLEleme nt.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\xml\XMLTrans former.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\util\xml\XMLUtils .class
[delete] Deleting directory C:\temp\ant\build\classes\com\dexia\common\util
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\weblogic\ServerSt artupMonitor.cla
ss
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\weblogic\Throwabl eHandler.class
[delete] Deleting
C:\temp\ant\build\classes\com\dexia\common\weblogic\WebLogic LogNotificationL
istener.class
[delete] Deleting C:\temp\ant\build\classes\META-INF\Manifest.mf
[delete] Deleting directory C:\temp\ant\build\classes\META-INF
[delete] Deleting C:\temp\ant\build\classes\needthis.txt
[delete] Deleting C:\temp\ant\build\classes\version.txt
[mkdir] Created dir: C:\temp\ant\build\classes\META-INF
prepare:
ejbdoclet:
compile:
[javac] com\dexia\common\ejb\EJBHomeHolder.java added as
com/dexia/common/ejb/EJBHomeHolder.class doesn't exist.
[javac] com\dexia\common\ejb\EJBUtils.java added as
com/dexia/common/ejb/EJBUtils.class doesn't exist.
[javac] com\dexia\common\ged\GED.java added as
com/dexia/common/ged/GED.class doesn't exist.
[javac] com\dexia\common\ged\GEDDocument.java added as
com/dexia/common/ged/GEDDocument.class doesn't exist.
[javac] com\dexia\common\io\CustomizedBase64Decoder.java added as
com/dexia/common/io/CustomizedBase64Decoder.class doesn't exist.
[javac] com\dexia\common\io\CustomizedBase64Encoder.java added as
com/dexia/common/io/CustomizedBase64Encoder.class doesn't exist.
[javac] com\dexia\common\io\FileUtils.java added as
com/dexia/common/io/FileUtils.class doesn't exist.
[javac] com\dexia\common\io\StreamUtils.java added as
com/dexia/common/io/StreamUtils.class doesn't exist.
[javac] com\dexia\common\io\WeakFile.java added as
com/dexia/common/io/WeakFile.class doesn't exist.
[javac] com\dexia\common\io\WeakFileInputStream.java added as
com/dexia/common/io/WeakFileInputStream.class doesn't exist.
[javac] com\dexia\common\io\XORInputStream.java added as
com/dexia/common/io/XORInputStream.class doesn't exist.
[javac] com\dexia\common\io\XOROutputStream.java added as
com/dexia/common/io/XOROutputStream.class doesn't exist.
[javac] com\dexia\common\jndi\AbstractServiceEJB.java added as
com/dexia/common/jndi/AbstractServiceEJB.class doesn't exist.
[javac] com\dexia\common\jndi\AbstractServiceJMS.java added as
com/dexia/common/jndi/AbstractServiceJMS.class doesn't exist.
[javac] com\dexia\common\jndi\AbstractServiceLocator.java added as
com/dexia/common/jndi/AbstractServiceLocator.class doesn't exist.
[javac] com\dexia\common\jndi\AbstractServiceWeb.java added as
com/dexia/common/jndi/AbstractServiceWeb.class doesn't exist.
[javac] com\dexia\common\jndi\EnvironmentEntriesHolder.java added as
com/dexia/common/jndi/EnvironmentEntriesHolder.class doesn't exist.
[javac] com\dexia\common\jndi\ServiceEJB.java added as
com/dexia/common/jndi/ServiceEJB.class doesn't exist.
[javac] com\dexia\common\jndi\ServiceJMS.java added as
com/dexia/common/jndi/ServiceJMS.class doesn't exist.
[javac] com\dexia\common\jndi\ServiceLocator.java added as
com/dexia/common/jndi/ServiceLocator.class doesn't exist.
[javac] com\dexia\common\lang\ChainedException.java added as
com/dexia/common/lang/ChainedException.class doesn't exist.
[javac] com\dexia\common\lang\ChainedRuntimeException.java added as
com/dexia/common/lang/ChainedRuntimeException.class doesn't exist.
[javac] com\dexia\common\lang\FieldException.java added as
com/dexia/common/lang/FieldException.class doesn't exist.
[javac] com\dexia\common\lang\MultiFieldException.java added as
com/dexia/common/lang/MultiFieldException.class doesn't exist.
[javac] com\dexia\common\lang\ObjectDoesNotExistException.java added as
com/dexia/common/lang/ObjectDoesNotExistException.class doesn't exist.
[javac] com\dexia\common\lang\PKIllegalStateException.java added as
com/dexia/common/lang/PKIllegalStateException.class doesn't exist.
[javac] com\dexia\common\lang\SystemException.java added as
com/dexia/common/lang/SystemException.class doesn't exist.
[javac] com\dexia\common\mail\Fax.java added as
com/dexia/common/mail/Fax.class doesn't exist.
[javac] com\dexia\common\mail\Mail.java added as
com/dexia/common/mail/Mail.class doesn't exist.
[javac] com\dexia\common\mail\MailProducer.java added as
com/dexia/common/mail/MailProducer.class doesn't exist.
[javac] com\dexia\common\security\Security.java added as
com/dexia/common/security/Security.class doesn't exist.
[javac] com\dexia\common\servlet\ServletUtils.java added as
com/dexia/common/servlet/ServletUtils.class doesn't exist.
[javac] com\dexia\common\servlet\SessionConsign.java added as
com/dexia/common/servlet/SessionConsign.class doesn't exist.
[javac] com\dexia\common\servlet\WebFile.java added as
com/dexia/common/servlet/WebFile.class doesn't exist.
[javac] com\dexia\common\servlet\download\ByteArrayDownloadJob.java added as
com/dexia/common/servlet/download/ByteArrayDownloadJob.class doesn't exist.
[javac] com\dexia\common\servlet\download\ContentDownloadJob.java added as
com/dexia/common/servlet/download/ContentDownloadJob.class doesn't exist.
[javac] com\dexia\common\servlet\download\DownloadJob.java added as
com/dexia/common/servlet/download/DownloadJob.class doesn't exist.
[javac] com\dexia\common\servlet\download\DownloadManager.java added as
com/dexia/common/servlet/download/DownloadManager.class doesn't exist.
[javac] com\dexia\common\servlet\download\DownloadResponseCode.java added as
com/dexia/common/servlet/download/DownloadResponseCode.class doesn't exist.
[javac] com\dexia\common\servlet\download\DownloadServlet.java added as
com/dexia/common/servlet/download/DownloadServlet.class doesn't exist.
[javac] com\dexia\common\servlet\download\EasyDownloadServlet.java added as
com/dexia/common/servlet/download/EasyDownloadServlet.class doesn't exist.
[javac] com\dexia\common\servlet\download\FileDownloadJob.java added as
com/dexia/common/servlet/download/FileDownloadJob.class doesn't exist.
[javac] com\dexia\common\servlet\download\GenericDownloader.java added as
com/dexia/common/servlet/download/GenericDownloader.class doesn't exist.
[javac] com\dexia\common\servlet\download\InputStreamDownloadJob.jav a added
as com/dexia/common/servlet/download/InputStreamDownloadJob.cla ss doesn't
exist.
[javac] com\dexia\common\servlet\download\MergedRTFDownloadJob.java added as
com/dexia/common/servlet/download/MergedRTFDownloadJob.class doesn't exist.
[javac] com\dexia\common\servlet\upload\UploadManager.java added as
com/dexia/common/servlet/upload/UploadManager.class doesn't exist.
[javac] com\dexia\common\servlet\upload\UploadRequest.java added as
com/dexia/common/servlet/upload/UploadRequest.class doesn't exist.
[javac] com\dexia\common\servlet\upload\UploadResult.java added as
com/dexia/common/servlet/upload/UploadResult.class doesn't exist.
[javac] com\dexia\common\servlet\upload\UploadServlet.java added as
com/dexia/common/servlet/upload/UploadServlet.class doesn't exist.
[javac] com\dexia\common\servlet\upload\UploadWrapper.java added as
com/dexia/common/servlet/upload/UploadWrapper.class doesn't exist.
[javac] com\dexia\common\servlet\upload\UploadedFile.java added as
com/dexia/common/servlet/upload/UploadedFile.class doesn't exist.
[javac] com\dexia\common\sql\DataSourceHolder.java added as
com/dexia/common/sql/DataSourceHolder.class doesn't exist.
[javac] com\dexia\common\sql\MSSQLError.java added as
com/dexia/common/sql/MSSQLError.class doesn't exist.
[javac] com\dexia\common\sql\SQLUtils.java added as
com/dexia/common/sql/SQLUtils.class doesn't exist.
[javac] com\dexia\common\sql\SecureDataSource.java added as
com/dexia/common/sql/SecureDataSource.class doesn't exist.
[javac] com\dexia\common\sql\SmartResultSet.java added as
com/dexia/common/sql/SmartResultSet.class doesn't exist.
[javac] com\dexia\common\util\AbstractRTFTableModel.java added as
com/dexia/common/util/AbstractRTFTableModel.class doesn't exist.
[javac] com\dexia\common\util\AbstractStateHolder.java added as
com/dexia/common/util/AbstractStateHolder.class doesn't exist.
[javac] com\dexia\common\util\AdresseFormater.java added as
com/dexia/common/util/AdresseFormater.class doesn't exist.
[javac] com\dexia\common\util\AppServerLogger.java added as
com/dexia/common/util/AppServerLogger.class doesn't exist.
[javac] com\dexia\common\util\CalculatriceMontant.java added as
com/dexia/common/util/CalculatriceMontant.class doesn't exist.
[javac] com\dexia\common\util\CharArray.java added as
com/dexia/common/util/CharArray.class doesn't exist.
[javac] com\dexia\common\util\CharUtils.java added as
com/dexia/common/util/CharUtils.class doesn't exist.
[javac] com\dexia\common\util\CollectionFactory.java added as
com/dexia/common/util/CollectionFactory.class doesn't exist.
[javac] com\dexia\common\util\Consign.java added as
com/dexia/common/util/Consign.class doesn't exist.
[javac] com\dexia\common\util\DateFormater.java added as
com/dexia/common/util/DateFormater.class doesn't exist.
[javac] com\dexia\common\util\DateUtils.java added as
com/dexia/common/util/DateUtils.class doesn't exist.
[javac] com\dexia\common\util\DebugUtils.java added as
com/dexia/common/util/DebugUtils.class doesn't exist.
[javac] com\dexia\common\util\Delai.java added as
com/dexia/common/util/Delai.class doesn't exist.
[javac] com\dexia\common\util\Dictionnaire.java added as
com/dexia/common/util/Dictionnaire.class doesn't exist.
[javac] com\dexia\common\util\Displayable.java added as
com/dexia/common/util/Displayable.class doesn't exist.
[javac] com\dexia\common\util\EntreeDictionnaire.java added as
com/dexia/common/util/EntreeDictionnaire.class doesn't exist.
[javac] com\dexia\common\util\Enumerated.java added as
com/dexia/common/util/Enumerated.class doesn't exist.
[javac] com\dexia\common\util\EtatCivilFormater.java added as
com/dexia/common/util/EtatCivilFormater.class doesn't exist.
[javac] com\dexia\common\util\FakeDataSource.java added as
com/dexia/common/util/FakeDataSource.class doesn't exist.
[javac] com\dexia\common\util\FileUtils.java added as
com/dexia/common/util/FileUtils.class doesn't exist.
[javac] com\dexia\common\util\GUID.java added as
com/dexia/common/util/GUID.class doesn't exist.
[javac] com\dexia\common\util\GUIDHelper.java added as
com/dexia/common/util/GUIDHelper.class doesn't exist.
[javac] com\dexia\common\util\Historique.java added as
com/dexia/common/util/Historique.class doesn't exist.
[javac] com\dexia\common\util\HtmlConverter.java added as
com/dexia/common/util/HtmlConverter.class doesn't exist.
[javac] com\dexia\common\util\Identifiable.java added as
com/dexia/common/util/Identifiable.class doesn't exist.
[javac] com\dexia\common\util\Intervalle.java added as
com/dexia/common/util/Intervalle.class doesn't exist.
[javac] com\dexia\common\util\LazyLoadingPersistent.java added as
com/dexia/common/util/LazyLoadingPersistent.class doesn't exist.
[javac] com\dexia\common\util\Logger.java added as
com/dexia/common/util/Logger.class doesn't exist.
[javac] com\dexia\common\util\MRUCache.java added as
com/dexia/common/util/MRUCache.class doesn't exist.
[javac] com\dexia\common\util\MainArgumentsHolder.java added as
com/dexia/common/util/MainArgumentsHolder.class doesn't exist.
[javac] com\dexia\common\util\MimeUtils.java added as
com/dexia/common/util/MimeUtils.class doesn't exist.
[javac] com\dexia\common\util\MiniGED.java added as
com/dexia/common/util/MiniGED.class doesn't exist.
[javac] com\dexia\common\util\Persistent.java added as
com/dexia/common/util/Persistent.class doesn't exist.
[javac] com\dexia\common\util\PersistentContainer.java added as
com/dexia/common/util/PersistentContainer.class doesn't exist.
[javac] com\dexia\common\util\PersistentState.java added as
com/dexia/common/util/PersistentState.class doesn't exist.
[javac] com\dexia\common\util\PrimaryKey.java added as
com/dexia/common/util/PrimaryKey.class doesn't exist.
[javac] com\dexia\common\util\PrivateAccess.java added as
com/dexia/common/util/PrivateAccess.class doesn't exist.
[javac] com\dexia\common\util\RTFConverter.java added as
com/dexia/common/util/RTFConverter.class doesn't exist.
[javac] com\dexia\common\util\RTFTable.java added as
com/dexia/common/util/RTFTable.class doesn't exist.
[javac] com\dexia\common\util\Registry.java added as
com/dexia/common/util/Registry.class doesn't exist.
[javac] com\dexia\common\util\RegistryException.java added as
com/dexia/common/util/RegistryException.class doesn't exist.
[javac] com\dexia\common\util\SmartCollection.java added as
com/dexia/common/util/SmartCollection.class doesn't exist.
[javac] com\dexia\common\util\SmartCollections.java added as
com/dexia/common/util/SmartCollections.class doesn't exist.
[javac] com\dexia\common\util\StringUtils.java added as
com/dexia/common/util/StringUtils.class doesn't exist.
[javac] com\dexia\common\util\TelephoneFormatter.java added as
com/dexia/common/util/TelephoneFormatter.class doesn't exist.
[javac] com\dexia\common\util\URLBuilder.java added as
com/dexia/common/util/URLBuilder.class doesn't exist.
[javac] com\dexia\common\util\Utils.java added as
com/dexia/common/util/Utils.class doesn't exist.
[javac] com\dexia\common\util\csv\AbstractCsvModel.java added as
com/dexia/common/util/csv/AbstractCsvModel.class doesn't exist.
[javac] com\dexia\common\util\csv\CsvFileBuilder.java added as
com/dexia/common/util/csv/CsvFileBuilder.class doesn't exist.
[javac] com\dexia\common\util\dao\AbstractDAO.java added as
com/dexia/common/util/dao/AbstractDAO.class doesn't exist.
[javac] com\dexia\common\util\dao\DAO.java added as
com/dexia/common/util/dao/DAO.class doesn't exist.
[javac] com\dexia\common\util\pdf\FDFMerger.java added as
com/dexia/common/util/pdf/FDFMerger.class doesn't exist.
[javac] com\dexia\common\util\pdf\FieldDef.java added as
com/dexia/common/util/pdf/FieldDef.class doesn't exist.
[javac] com\dexia\common\util\pdf\Merger.java added as
com/dexia/common/util/pdf/Merger.class doesn't exist.
[javac] com\dexia\common\util\pdf\PDFMerger.java added as
com/dexia/common/util/pdf/PDFMerger.class doesn't exist.
[javac] com\dexia\common\util\pdf\PDFUtils.java added as
com/dexia/common/util/pdf/PDFUtils.class doesn't exist.
[javac] com\dexia\common\util\pdf\ValueFieldDef.java added as
com/dexia/common/util/pdf/ValueFieldDef.class doesn't exist.
[javac] com\dexia\common\util\rtf\AbstractRTFTableModel.java added as
com/dexia/common/util/rtf/AbstractRTFTableModel.class doesn't exist.
[javac] com\dexia\common\util\rtf\RTFConverter.java added as
com/dexia/common/util/rtf/RTFConverter.class doesn't exist.
[javac] com\dexia\common\util\rtf\RTFFlow.java added as
com/dexia/common/util/rtf/RTFFlow.class doesn't exist.
[javac] com\dexia\common\util\rtf\RTFParagraph.java added as
com/dexia/common/util/rtf/RTFParagraph.class doesn't exist.
[javac] com\dexia\common\util\rtf\RTFTable.java added as
com/dexia/common/util/rtf/RTFTable.class doesn't exist.
[javac] com\dexia\common\util\rtf\RTFUtils.java added as
com/dexia/common/util/rtf/RTFUtils.class doesn't exist.
[javac] com\dexia\common\util\rtf\RTFifiable.java added as
com/dexia/common/util/rtf/RTFifiable.class doesn't exist.
[javac] com\dexia\common\util\xml\StreamTransformer.java added as
com/dexia/common/util/xml/StreamTransformer.class doesn't exist.
[javac] com\dexia\common\util\xml\XMLDocument.java added as
com/dexia/common/util/xml/XMLDocument.class doesn't exist.
[javac] com\dexia\common\util\xml\XMLElement.java added as
com/dexia/common/util/xml/XMLElement.class doesn't exist.
[javac] com\dexia\common\util\xml\XMLTransformer.java added as
com/dexia/common/util/xml/XMLTransformer.class doesn't exist.
[javac] com\dexia\common\util\xml\XMLUtils.java added as
com/dexia/common/util/xml/XMLUtils.class doesn't exist.
[javac] com\dexia\common\weblogic\ServerStartupMonitor.java added as
com/dexia/common/weblogic/ServerStartupMonitor.class doesn't exist.
[javac] com\dexia\common\weblogic\ThrowableHandler.java added as
com/dexia/common/weblogic/ThrowableHandler.class doesn't exist.
[javac] com\dexia\common\weblogic\WebLogicLogNotificationListener.ja va added
as com/dexia/common/weblogic/WebLogicLogNotificationListener.cl ass doesn't
exist.
[javac] Compiling 128 source files to C:\temp\ant\build\classes
[javac] Using external javac compiler
[javac] Compilation arguments:
'-deprecation'
'-d'
'C:\temp\ant\build\classes'
'-classpath'
'C:\temp\ant\build\classes;C:\classes\jars\common_business.j ar;C:\classes\ja
rs\common_geographie.jar;C:\classes\lib\cos.jar;C:\classes\l ib\jFdfTk.jar;C:
\classes\lib\fop.jar;C:\classes\lib\xercesImpl.jar;C:\classe s\lib\batik.jar;
C:\classes\lib\avalon-framework.jar;C:\classes\lib\commons-h ttpclient.jar;C:
\classes\lib\commons-logging.jar;C:\bin\bea\wlserver6.1\lib\ weblogic.jar;C:\
bin\ant\lib\ant.jar;C:\bin\jdk1.3.1_09\lib\tools.jar;C:\bin\ ant\lib\ant-laun
cher.jar'
'-sourcepath'
'W:\root\JAR_common_util\sources'
'-g'
The ' characters around the executable and arguments are
not part of the command.
[javac] Files to be compiled:
W:\root\JAR_common_util\sources\com\dexia\common\ejb\EJBHome Holder.java
W:\root\JAR_common_util\sources\com\dexia\common\ejb\EJBUtil s.java
W:\root\JAR_common_util\sources\com\dexia\common\ged\GED.jav a
W:\root\JAR_common_util\sources\com\dexia\common\ged\GEDDocu ment.java
W:\root\JAR_common_util\sources\com\dexia\common\io\Customiz edBase64Decoder.
java
W:\root\JAR_common_util\sources\com\dexia\common\io\Customiz edBase64Encoder.
java
W:\root\JAR_common_util\sources\com\dexia\common\io\FileUtil s.java
W:\root\JAR_common_util\sources\com\dexia\common\io\StreamUt ils.java
W:\root\JAR_common_util\sources\com\dexia\common\io\WeakFile .java
W:\root\JAR_common_util\sources\com\dexia\common\io\WeakFile InputStream.java
W:\root\JAR_common_util\sources\com\dexia\common\io\XORInput Stream.java
W:\root\JAR_common_util\sources\com\dexia\common\io\XOROutpu tStream.java
W:\root\JAR_common_util\sources\com\dexia\common\jndi\Abstra ctServiceEJB.jav
a
W:\root\JAR_common_util\sources\com\dexia\common\jndi\Abstra ctServiceJMS.jav
a
W:\root\JAR_common_util\sources\com\dexia\common\jndi\Abstra ctServiceLocator
..java
W:\root\JAR_common_util\sources\com\dexia\common\jndi\Abstra ctServiceWeb.jav
a
W:\root\JAR_common_util\sources\com\dexia\common\jndi\Enviro nmentEntriesHold
er.java
W:\root\JAR_common_util\sources\com\dexia\common\jndi\Servic eEJB.java
W:\root\JAR_common_util\sources\com\dexia\common\jndi\Servic eJMS.java
W:\root\JAR_common_util\sources\com\dexia\common\jndi\Servic eLocator.java
W:\root\JAR_common_util\sources\com\dexia\common\lang\Chaine dException.java
W:\root\JAR_common_util\sources\com\dexia\common\lang\Chaine dRuntimeExceptio
n.java
W:\root\JAR_common_util\sources\com\dexia\common\lang\FieldE xception.java
W:\root\JAR_common_util\sources\com\dexia\common\lang\MultiF ieldException.ja
va
W:\root\JAR_common_util\sources\com\dexia\common\lang\Object DoesNotExistExce
ption.java
W:\root\JAR_common_util\sources\com\dexia\common\lang\PKIlle galStateExceptio
n.java
W:\root\JAR_common_util\sources\com\dexia\common\lang\System Exception.java
W:\root\JAR_common_util\sources\com\dexia\common\mail\Fax.ja va
W:\root\JAR_common_util\sources\com\dexia\common\mail\Mail.j ava
W:\root\JAR_common_util\sources\com\dexia\common\mail\MailPr oducer.java
W:\root\JAR_common_util\sources\com\dexia\common\security\Se curity.java
W:\root\JAR_common_util\sources\com\dexia\common\servlet\Ser vletUtils.java
W:\root\JAR_common_util\sources\com\dexia\common\servlet\Ses sionConsign.java
W:\root\JAR_common_util\sources\com\dexia\common\servlet\Web File.java
W:\root\JAR_common_util\sources\com\dexia\common\servlet\dow nload\ByteArrayD
ownloadJob.java
W:\root\JAR_common_util\sources\com\dexia\common\servlet\dow nload\ContentDow
nloadJob.java
W:\root\JAR_common_util\sources\com\dexia\common\servlet\dow nload\DownloadJo
b.java
W:\root\JAR_common_util\sources\com\dexia\common\servlet\dow nload\DownloadMa
nager.java
W:\root\JAR_common_util\sources\com\dexia\common\servlet\dow nload\DownloadRe
sponseCode.java
W:\root\JAR_common_util\sources\com\dexia\common\servlet\dow nload\DownloadSe
rvlet.java
W:\root\JAR_common_util\sources\com\dexia\common\servlet\dow nload\EasyDownlo
adServlet.java
W:\root\JAR_common_util\sources\com\dexia\common\servlet\dow nload\FileDownlo
adJob.java
W:\root\JAR_common_util\sources\com\dexia\common\servlet\dow nload\GenericDow
nloader.java
W:\root\JAR_common_util\sources\com\dexia\common\servlet\dow nload\InputStrea
mDownloadJob.java
W:\root\JAR_common_util\sources\com\dexia\common\servlet\dow nload\MergedRTFD
ownloadJob.java
W:\root\JAR_common_util\sources\com\dexia\common\servlet\upl oad\UploadManage
r.java
W:\root\JAR_common_util\sources\com\dexia\common\servlet\upl oad\UploadReques
t.java
W:\root\JAR_common_util\sources\com\dexia\common\servlet\upl oad\UploadResult
..java
W:\root\JAR_common_util\sources\com\dexia\common\servlet\upl oad\UploadServle
t.java
W:\root\JAR_common_util\sources\com\dexia\common\servlet\upl oad\UploadWrappe
r.java
W:\root\JAR_common_util\sources\com\dexia\common\servlet\upl oad\UploadedFile
..java
W:\root\JAR_common_util\sources\com\dexia\common\sql\DataSou rceHolder.java
W:\root\JAR_common_util\sources\com\dexia\common\sql\MSSQLEr ror.java
W:\root\JAR_common_util\sources\com\dexia\common\sql\SQLUtil s.java
W:\root\JAR_common_util\sources\com\dexia\common\sql\SecureD ataSource.java
W:\root\JAR_common_util\sources\com\dexia\common\sql\SmartRe sultSet.java
W:\root\JAR_common_util\sources\com\dexia\common\util\Abstra ctRTFTableModel.
java
W:\root\JAR_common_util\sources\com\dexia\common\util\Abstra ctStateHolder.ja
va
W:\root\JAR_common_util\sources\com\dexia\common\util\Adress eFormater.java
W:\root\JAR_common_util\sources\com\dexia\common\util\AppSer verLogger.java
W:\root\JAR_common_util\sources\com\dexia\common\util\Calcul atriceMontant.ja
va
W:\root\JAR_common_util\sources\com\dexia\common\util\CharAr ray.java
W:\root\JAR_common_util\sources\com\dexia\common\util\CharUt ils.java
W:\root\JAR_common_util\sources\com\dexia\common\util\Collec tionFactory.java
W:\root\JAR_common_util\sources\com\dexia\common\util\Consig n.java
W:\root\JAR_common_util\sources\com\dexia\common\util\DateFo rmater.java
W:\root\JAR_common_util\sources\com\dexia\common\util\DateUt ils.java
W:\root\JAR_common_util\sources\com\dexia\common\util\DebugU tils.java
W:\root\JAR_common_util\sources\com\dexia\common\util\Delai. java
W:\root\JAR_common_util\sources\com\dexia\common\util\Dictio nnaire.java
W:\root\JAR_common_util\sources\com\dexia\common\util\Displa yable.java
W:\root\JAR_common_util\sources\com\dexia\common\util\Entree Dictionnaire.jav
a
W:\root\JAR_common_util\sources\com\dexia\common\util\Enumer ated.java
W:\root\JAR_common_util\sources\com\dexia\common\util\EtatCi vilFormater.java
W:\root\JAR_common_util\sources\com\dexia\common\util\FakeDa taSource.java
W:\root\JAR_common_util\sources\com\dexia\common\util\FileUt ils.java
W:\root\JAR_common_util\sources\com\dexia\common\util\GUID.j ava
W:\root\JAR_common_util\sources\com\dexia\common\util\GUIDHe lper.java
W:\root\JAR_common_util\sources\com\dexia\common\util\Histor ique.java
W:\root\JAR_common_util\sources\com\dexia\common\util\HtmlCo nverter.java
W:\root\JAR_common_util\sources\com\dexia\common\util\Identi fiable.java
W:\root\JAR_common_util\sources\com\dexia\common\util\Interv alle.java
W:\root\JAR_common_util\sources\com\dexia\common\util\LazyLo adingPersistent.
java
W:\root\JAR_common_util\sources\com\dexia\common\util\Logger .java
W:\root\JAR_common_util\sources\com\dexia\common\util\MRUCac he.java
W:\root\JAR_common_util\sources\com\dexia\common\util\MainAr gumentsHolder.ja
va
W:\root\JAR_common_util\sources\com\dexia\common\util\MimeUt ils.java
W:\root\JAR_common_util\sources\com\dexia\common\util\MiniGE D.java
W:\root\JAR_common_util\sources\com\dexia\common\util\Persis tent.java
W:\root\JAR_common_util\sources\com\dexia\common\util\Persis tentContainer.ja
va
W:\root\JAR_common_util\sources\com\dexia\common\util\Persis tentState.java
W:\root\JAR_common_util\sources\com\dexia\common\util\Primar yKey.java
W:\root\JAR_common_util\sources\com\dexia\common\util\Privat eAccess.java
W:\root\JAR_common_util\sources\com\dexia\common\util\RTFCon verter.java
W:\root\JAR_common_util\sources\com\dexia\common\util\RTFTab le.java
W:\root\JAR_common_util\sources\com\dexia\common\util\Regist ry.java
W:\root\JAR_common_util\sources\com\dexia\common\util\Regist ryException.java
W:\root\JAR_common_util\sources\com\dexia\common\util\SmartC ollection.java
W:\root\JAR_common_util\sources\com\dexia\common\util\SmartC ollections.java
W:\root\JAR_common_util\sources\com\dexia\common\util\String Utils.java
W:\root\JAR_common_util\sources\com\dexia\common\util\Teleph oneFormatter.jav
a
W:\root\JAR_common_util\sources\com\dexia\common\util\URLBui lder.java
W:\root\JAR_common_util\sources\com\dexia\common\util\Utils. java
W:\root\JAR_common_util\sources\com\dexia\common\util\csv\Ab stractCsvModel.j
ava
W:\root\JAR_common_util\sources\com\dexia\common\util\csv\Cs vFileBuilder.jav
a
W:\root\JAR_common_util\sources\com\dexia\common\util\dao\Ab stractDAO.java
W:\root\JAR_common_util\sources\com\dexia\common\util\dao\DA O.java
W:\root\JAR_common_util\sources\com\dexia\common\util\pdf\FD FMerger.java
W:\root\JAR_common_util\sources\com\dexia\common\util\pdf\Fi eldDef.java
W:\root\JAR_common_util\sources\com\dexia\common\util\pdf\Me rger.java
W:\root\JAR_common_util\sources\com\dexia\common\util\pdf\PD FMerger.java
W:\root\JAR_common_util\sources\com\dexia\common\util\pdf\PD FUtils.java
W:\root\JAR_common_util\sources\com\dexia\common\util\pdf\Va lueFieldDef.java
W:\root\JAR_common_util\sources\com\dexia\common\util\rtf\Ab stractRTFTableMo
del.java
W:\root\JAR_common_util\sources\com\dexia\common\util\rtf\RT FConverter.java
W:\root\JAR_common_util\sources\com\dexia\common\util\rtf\RT FFlow.java
W:\root\JAR_common_util\sources\com\dexia\common\util\rtf\RT FParagraph.java
W:\root\JAR_common_util\sources\com\dexia\common\util\rtf\RT FTable.java
W:\root\JAR_common_util\sources\com\dexia\common\util\rtf\RT FUtils.java
W:\root\JAR_common_util\sources\com\dexia\common\util\rtf\RT Fifiable.java
W:\root\JAR_common_util\sources\com\dexia\common\util\xml\St reamTransformer.
java
W:\root\JAR_common_util\sources\com\dexia\common\util\xml\XM LDocument.java
W:\root\JAR_common_util\sources\com\dexia\common\util\xml\XM LElement.java
W:\root\JAR_common_util\sources\com\dexia\common\util\xml\XM LTransformer.jav
a
W:\root\JAR_common_util\sources\com\dexia\common\util\xml\XM LUtils.java
W:\root\JAR_common_util\sources\com\dexia\common\weblogic\Se rverStartupMonit
or.java
W:\root\JAR_common_util\sources\com\dexia\common\weblogic\Th rowableHandler.j
ava
W:\root\JAR_common_util\sources\com\dexia\common\weblogic\We bLogicLogNotific
ationListener.java
[javac]
W:\root\JAR_common_util\sources\com\dexia\common\util\Adress eFormater.java:1
5: warning: com.dexia.common.geographie.business.AdresseValueAssembler in
com.dexia.common.geographie.business has been deprecated
[javac] public static String format(AdresseValueAssembler adresseVA) {
[javac] ^
[javac]
W:\root\JAR_common_util\sources\com\dexia\common\util\Adress eFormater.java:8
2: warning: com.dexia.common.geographie.business.AdresseValueAssembler in
[javac] public static String formatEnUneLigne(AdresseValueAssembler
adresseVA) {
[javac] ^
[javac]
or.java:35: warning: weblogic.common.T3ServicesDef in weblogic.common has
been deprecated
[javac] private T3ServicesDef services;
[javac] ^
[javac]
or.java:94: warning: weblogic.common.T3ServicesDef in weblogic.common has
been deprecated
[javac] public void setServices(T3ServicesDef _services)
[javac] ^
[javac]
ationListener.java:31: warning: weblogic.common.T3ServicesDef in
weblogic.common has been deprecated
[javac] ^
[javac]
ationListener.java:103: warning: weblogic.common.T3ServicesDef in
[javac] public void setServices(T3ServicesDef _services) {
[javac] ^
[javac]
[javac] ^
[javac]
W:\root\JAR_common_util\sources\com\dexia\common\util\Adress eFormater.java:4
3: warning: getComplement() in com.dexia.common.business.Adresse has been
deprecated
[javac] String complement = adresse.getComplement();
[javac] ^
[javac]
W:\root\JAR_common_util\sources\com\dexia\common\util\Adress eFormater.java:6
3: warning: isCedexPresent() in com.dexia.common.business.Adresse has been
deprecated
[javac] if (adresse.isCedexPresent()) {
[javac] ^
[javac]
6: warning: getCedex() in com.dexia.common.business.Adresse has been
deprecated
[javac] String cedex = adresse.getCedex();
[javac] ^
[javac]
adresseVA) {
[javac] ^
[javac]
06: warning: getComplement() in com.dexia.common.business.Adresse has been
deprecated
[javac] ^
[javac]
27: warning: isCedexPresent() in com.dexia.common.business.Adresse has been
deprecated
[javac] ^
[javac]
30: warning: getCedex() in com.dexia.common.business.Adresse has been
deprecated
[javac] ^
[javac]
been deprecated
[javac] ^
[javac]
[javac] ^
[javac] 16 warnings
[javac]
[javac]
build:
[delete] Deleting: C:\classes\jars\common_util.jar
[jar] Building jar: C:\classes\jars\common_util.jar
BUILD FAILED: java.lang.NoSuchMethodError
Total time: 18 seconds
Re: Problem runnning ant 1.6 with eclipse 2.1.2 [message #147978 is a reply to message #147889] Tue, 09 March 2004 11:49 Go to previous messageGo to next message
We have a bug in Eclipse 2.1.2.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=45985
Fixed in 2.1.3 and the 3.0 stream
HTH
Darins
"Dominique Jean-Prost" <djeanprost@NOSPAMsofaxis.com> wrote in message
news:c2k130$sea$2@eclipse.org...
> Hello,
> Dom
> 22678982
> compile, build]
> pre_init:
> init:
> is up to date.
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> ss
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> s
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> class
> [delete] Deleting
> s
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> dJob.class
> [delete] Deleting
> ob.class
> [delete] Deleting
> s
> [delete] Deleting
> class
> [delete] Deleting
> Code.class
> [delete] Deleting
> class
> [delete] Deleting
> let.class
> [delete] Deleting
> class
> [delete] Deleting
> r.class
> [delete] Deleting
> oadJob.class
> [delete] Deleting
> dJob.class
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> s
> [delete] Deleting
> s
> [delete] Deleting
> [delete] Deleting
> s
> [delete] Deleting
> s
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> lass
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> s
> [delete] Deleting
> [delete] Deleting
> tentAttribute.class
> [delete] Deleting
> [delete] Deleting
> tentMap.class
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> s
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> ass
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> [delete] Deleting
> ss
> [delete] Deleting
> [delete] Deleting
> istener.class
> prepare:
> ejbdoclet:
> compile:
as
exist.
as
exist.
as
added
> exist.
as
exist.
added
> exist.
> '-deprecation'
> '-d'
> '-classpath'
> cher.jar'
> '-sourcepath'
> '-g'
> java
> java
> a
> a
> .java
> a
> er.java
> n.java
> va
> ption.java
> n.java
> ownloadJob.java
> nloadJob.java
> b.java
> nager.java
> sponseCode.java
> rvlet.java
> adServlet.java
> adJob.java
> nloader.java
> mDownloadJob.java
> ownloadJob.java
> r.java
> t.java
> .java
> t.java
> r.java
> .java
> java
> va
> va
> a
> java
> va
> va
> a
> ava
> a
> del.java
> java
> a
> or.java
> ava
> ationListener.java
> [javac]
> [javac] ^
> [javac]
> adresseVA) {
> [javac] ^
> [javac]
> been deprecated
> [javac] ^
> [javac]
> been deprecated
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> [javac] ^
> [javac]
> deprecated
> [javac] ^
> [javac]
> deprecated
> [javac] ^
> [javac]
> deprecated
> [javac] ^
> [javac]
> adresseVA) {
> [javac] ^
> [javac]
> deprecated
> [javac] ^
> [javac]
been
> deprecated
> [javac] ^
> [javac]
> deprecated
> [javac] ^
> [javac]
> been deprecated
> [javac] ^
> [javac]
> [javac] ^
> [javac] 16 warnings
> [javac]
> [javac]
> build:
Re: Problem runnning ant 1.6 with eclipse 2.1.2 [message #148053 is a reply to message #147978] Wed, 10 March 2004 10:13 Go to previous message
thanks
"Darin Swanson" <Darin_Swanson@us.ibm.com> a
Previous Topic:Import/Export of Preferences
Next Topic:Integration builds
Current Time: Sat Jul 26 12:36:56 EDT 2025
Powered by FUDForum. Page generated in 0.04155 seconds
