Home » Eclipse Projects » GEF » Simple example code using GEF
Simple example code using GEF [message #147887] Tue, 17 August 2004 10:28 Go to next message
Originally posted by: deckerson.spss.com
Hello, I am looking for some simple example code that I can use to get a
feel for all parts of GEF. Where can I find this code? The example code
provided with GEF 3.0 is to advanced for my level.
thanks...
Re: Simple example code using GEF [message #147904 is a reply to message #147887] Tue, 17 August 2004 10:48 Go to previous messageGo to next message
This is being worked on. There should be one available in a day or so.
"David" <deckerson@spss.com> wrote in message
news:cft4jt$vo6$1@eclipse.org...
> thanks...
Re: Simple example code using GEF [message #147934 is a reply to message #147904] Tue, 17 August 2004 13:28 Go to previous messageGo to next message
Great! Please let me know when it is available.
"Pratik Shah" <ppshah@us.ibm.com> wrote in message
news:cft5m0$2ed$1@eclipse.org...
code
> > thanks...
Re: Simple example code using GEF [message #147973 is a reply to message #147934] Tue, 17 August 2004 16:44 Go to previous messageGo to next message
I found http://eclipse-wiki.info/GefExamples very helpful.
- Sean
> code
>>>thanks...
Re: Simple example code using GEF [message #149838 is a reply to message #147887] Fri, 03 September 2004 08:06 Go to previous message
Originally posted by: eclipse.jsdk.de
Hello David,
you can find a very simple example in the eclipse sourcecode repository.
Add a new Respository Location on your CVS Repositories Perspective with
the following Properties:
:pserver:anonymous@dev.eclipse.org:/home/tools
Open the head and you will find a project:
org.eclipse.gef.examples.shapes
which is not included in the Examples Distribution and is quite easy.
cu,
Dieter
> thanks...
Previous Topic:Simple GEF Editor 3.0
Next Topic:Manhatten routing dummy connections
Current Time: Fri Jul 18 22:44:20 EDT 2025
Powered by FUDForum. Page generated in 0.04083 seconds
