Re: Connect BIRT to LDAP database [message #158664 is a reply to message #157354] |
Fri, 05 May 2006 06:32  |
Originally posted by: jarif.despammed.com
Holger Buchner wrote:
> Hi Scott,
> before they were bought by Oracle, the company Octetstring published a
> LDAP2JDBC-bridge-driver, that enabled to access a LDAP-Server via
> JDBC-commands.
> Sorrowly, the page is redirected to Oracle right now and i didn't manage
> to find the driver there so far.
> Perhaps someone has an idea where to find it.
No idea, but Novell also has a jdbc-driver for LDAP, and it's
downloadable from their site.
> Holger
> Scott Rosenbaum schrieb:
>> Vineeta,
>> Do you have any experience writing Java code against a LDAP database?
>> If you do, I would recommend writing a Java access class and then use
>> a ScriptedData source. You might try looking at the BirtWorld article
>> "Java and Session Objects in BIRT" if you need help with a
>> ScriptedDataSource.
>> Scott Rosenbaum
>> Birt PMC
>> Vineeta Gupta wrote:
>>> Hi!
>>> Can you help me with the drivers and the format to use to connect to
>>> an LDAP database.
FUDForum. Page generated in 0.03652 seconds
