Create my toolchain [message #147522] |
Sun, 26 June 2005 13:28  |
Originally posted by: hibou.bonbon.net
I have followed the tutorial to make a custum toolchain (Managed Build
Extensibility Reference Document (for CDT 2.1))
Then, I run the runtime workbench, I can create the new project-type.
But the makefile generator create this makefile while I am importing a
source file :
# Automatically-generated file. Do not edit!
ROOT := ..
-include $(ROOT)/makefile.init
RM := rm -f
# All of the sources participating in the build are defined here
-include sources.mk
-include $(SUBDIRS:%=%/subdir.mk)
-include objects.mk
-include $(DEPS)
-include $(ROOT)/makefile.defs
all: test
test: $(OBJS)
@echo 'Building target: $@'
null null $@ $(OBJS) $(USER_OBJS) $(LIBS)
@echo 'Finished building: $@'
clean:
-$(RM) $(OBJS) $(DEPS) test
..PHONY: all clean dependents
-include $(ROOT)/makefile.targets
As you can see, there is "null null". I don't know how to specify to the
makefile generator the tool which will link...
For compiling the source, there is no problem, it takes "ccc" :
C_SRCS += \
${addprefix $(ROOT)/, \
key.c \
C_UPPER_SRCS += \
# Each subdirectory must supply rules for building sources it contributes
%.o: $(ROOT)/%.c
@echo 'Building file: $<'
@echo ccc -c -w -o$@ $<
@ccc -c -w -o$@ $<
@echo 'Finished building: $<'
@echo ' '
hibou
Re: Create my toolchain [message #147780 is a reply to message #147732] |
Wed, 29 June 2005 17:12   |
In fact, it is not a problem of path. I am creating my own toolchain,
and it appears that the Makefile generator find the correct tools with
the extensions.
And yes I use PDE. So I extend the extension point :
org.eclipse.cdt.managedbuilder.core.buildDefinitions
Then I create a projectType. In it I created a Configuration. In it I
ceated a toolChain. And in the toolchain I added the builder, the
tagetPlateform and my tools.
PS : can you please write complete words. As I am not english, it is
quite hard to read you.
Senthil Kumar . S a écrit :
> hi This is from Senthil Kumar.
> u can add the path, where ur tool resides, in /etc/profile. Then u
> compile.
> How u hav added a new toolchain. did u use pde. I used pde, but i didnt
> get the tag called, <target> <configuration> etc.
> Expecting ur reply. Thank u in advance.
> Regards
> Senthil
Re: Create my toolchain [message #148905 is a reply to message #147522] |
Fri, 15 July 2005 07:56  |
Originally posted by: jonkersbart.gmail.com
hibou wrote:
> Hello,
> source file :
> ROOT := ..
> RM := rm -f
> -include sources.mk
> -include objects.mk
> -include $(DEPS)
> all: test
> test: $(OBJS)
> clean:
> C_SRCS += \
> key.c \
> C_UPPER_SRCS += \
> %.o: $(ROOT)/%.c
> @ccc -c -w -o$@ $<
> @echo ' '
Hey,
I have the same problem. Did you get it solved?
Bart
> hibou
FUDForum. Page generated in 0.08128 seconds
