Outline-window in Juno [message #1012857] |
Fri, 22 February 2013 10:43 |
Kitesurfer () Messages: 87 Registered: December 2009 |
Member |
I'm working with Juno recently. Functionality in Juno is that each editor(tab) can be "loosened" from Eclipse and goes on as a somewhat separate window. You just drag&drop an editor tab to the desktop and it happens.
However, on the loose window the Outline is not there. Suppose I have two loosened editor(tab)s ... how would I get an Outline on both windows ?
I ask this because when editting large files the Outline is a great way to navigate through a source ... so it would be great if every loosened editor would have the Outline also there by default (or configurable in the Preferences)
Thanks.
PS. Addition ... does anybody know what's the command to loosen an editortab ? ... so I could bind it to a function-key.
[Updated on: Fri, 22 February 2013 10:49] Report message to a moderator
FUDForum. Page generated in 0.07909 seconds
