editor on different monitor [message #147406] |
Sat, 08 April 2006 12:19  |
Originally posted by: shea08.eastlink.ca
I have a dual monitor setup. Is there a way I can put the editor on one
monitor, and the rest of the ide on the other? (I guess it would be MDI?)
On a 1024x768 screen, there is not much editing room.
~S
Re: editor on different monitor [message #149424 is a reply to message #147415] |
Fri, 21 April 2006 13:38  |
Originally posted by: eclipse3.rizzoweb.com
Jacek Pospychała wrote:
>> one monitor, and the rest of the ide on the other? (I guess it would
>> be MDI?)
> it was discussed somewhere here and as far as i remember, there are two
> solutions or rather workarounds:
> -use menu option "Window" -> "New window" and set one window to have
> only editor, while second with the rest of your needs.
> -stretch your eclipse window to span over both screens, assuming you
> have one big virtual screen)
The second one is the solution I recently recommended. If you open a new
Workbench window, you have to understand that they each maintain their
own GUI state, meaning you'll have two different sets of perspectives -
sort of like two different Eclipse's running at the same time. That can
be a powerful mode to work in, but may not be what is needed in this case.
There are 2 other options:
A) Stretch you Eclipse window across both monitors and set up your
perspectives such that the editors area occupies all of one of the
monitors and all other views occupy the other one.
B) All views (except editors) can be detached from the workbench window
and docked on the second monitor. That is nice if you have views that
you want to keep open but primarily focus on the editors and the main
Eclipse GUI components (toolbar, menu bar, etc.)
Hope this helps,
Eric
FUDForum. Page generated in 0.11213 seconds
