Home » Language IDEs » Java Development Tools (JDT) » Custom ASTNodes, OOP broken?
Custom ASTNodes, OOP broken? [message #147402] Thu, 04 March 2004 20:48 Go to next message
I'm trying to add custom ASTNode for my plug-in.
Unfortunately I have problem with the getNodeType() method.
How can I make sure that the custom node type constants are unique and
don't clash with existing declarations on ASTNode class.
I would have a class
public class CustomASTNode extends ASTNode {
public static final int MY_CUSTOM_STATEMENT = ?????????????
public class CustomStatement extends CustomASTNode {
public int getNodeType() {
return MY_CUSTOM_STATEMENT;
That raises a question: are we supposed to be able to modify the Model?
Cheers
Re: Custom ASTNodes, OOP broken? [message #147462 is a reply to message #147402] Fri, 05 March 2004 09:27 Go to previous messageGo to next message
not supported,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=36891
a.
Re: Custom ASTNodes, OOP broken? [message #148081 is a reply to message #147462] Wed, 10 March 2004 13:53 Go to previous messageGo to next message
hmmm working on something that should enable it, i hope
> not supported,
> a.
Re: Custom ASTNodes, OOP broken? [message #148155 is a reply to message #148081] Thu, 11 March 2004 09:26 Go to previous message
Originally posted by: olivier_thomann.ca.ibm.comNOSPAM
Le Wed, 10 Mar 2004 19:53:08 +0100, Charles-Philip Bentley
>> not supported,
I think the reason why extension are not supported is that there is no
need to add new nodes. The existing nodes must reflect the source code
and I believe they do.
We are adding more nodes to support the new 1.5 constructs. Could you
please give me an example or a reason why you would add new nodes?
Olivier
Previous Topic:source attachment with variable path
Next Topic:Code generation in Eclipse
Current Time: Sun Jul 27 06:46:08 EDT 2025
Powered by FUDForum. Page generated in 0.05002 seconds
