Home » Modeling » GMF (Graphical Modeling Framework) » approveRequest returns false but still a command is created and executed
approveRequest returns false but still a command is created and executed [message #147272] Tue, 21 August 2007 10:10 Go to next message
I created a custom EditHelperAdvice and implemented my own approveRequest
method. Depending on a value in the corresponding semantic model element it
returns false. This works so far.
I expected by implementing the approveRequest method to disallow the
creation of links between two nodes. Wheneven the target node is marked as
unchangeable it should be impossible to draw a link. I check the attribute
in approveRequest and return false if the node is marked (i.e. the attribute
is set).
But even if approveRequest returns false a command is created an executed.
After execution eclipse crashes with a stack overflow.
Am I missing something or is this a bug?
Greetings,
Alexander Dotor
Re: approveRequest returns false but still a command is created and executed [message #147281 is a reply to message #147272] Tue, 21 August 2007 10:22 Go to previous messageGo to next message
The error is:
java.lang.StackOverflowError
org.eclipse.core.runtime.ProgressMonitorWrapper.internalWork ed(ProgressMonitorWrapper.java:94)
org.eclipse.core.runtime.SubProgressMonitor.internalWorked(S ubProgressMonitor.java:155)
Greetings,
Alexander
"Alexander Dotor" <alexander.dotor@uni-bayreuth.de> schrieb im Newsbeitrag
news:faeroq$lnc$1@build.eclipse.org...
> Hello,
> it returns false. This works so far.
> attribute is set).
> executed. After execution eclipse crashes with a stack overflow.
> Greetings,
> Alexander Dotor
Re: approveRequest returns false but still a command is created and executed [message #147327 is a reply to message #147281] Tue, 21 August 2007 12:02 Go to previous messageGo to next message
Hi Alex,
On Tue, 21 Aug 2007 16:22:27 +0200, Alexander Dotor wrote:
> The error is:
I received this Stack Overflow Error when trying to share GMF's editing
domain with a custom view I wrote.
See a prior e-mail thread, still being discussed:
Newsgroups: eclipse.modeling.gmf
Subject: StackOverflowError with shared EditingDomain
Date: Tue, 24 Jul 2007 20:13:54 +0000 (UTC)
Andrew
Re: approveRequest returns false but still a command is created and executed [message #147379 is a reply to message #147281] Wed, 22 August 2007 03:50 Go to previous messageGo to next message
Hello Alexander,
Can you post here beggining of Stack trace?
Alex Shatalin
Re: approveRequest returns false but still a command is created and executed [message #148061 is a reply to message #147379] Tue, 28 August 2007 08:42 Go to previous messageGo to next message
How do I get to the beginning - it is too long! Here's the full stack trace
but due to the loop it is showing only the same two lines again and again:
eclipse.buildId=I20070625-1500
java.version=1.6.0_02
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments: -product org.eclipse.sdk.ide -pdelaunch
Command-line arguments: -product org.eclipse.sdk.ide -data C:\Dokumente und
Einstellungen\adotor\Eigene
Dateien\workspaces\eclipse_workspace/../runtime-New_configur ation -dev
file:C:/Dokumente und Einstellungen/adotor/Eigene
Dateien/workspaces/eclipse_workspace/.metadata/.plugins/org. eclipse.pde.core/Pure
GMF Projector/dev.properties -pdelaunch -os win32 -ws win32 -arch x86
Error
Tue Aug 28 14:40:33 CEST 2007
Unhandled event loop exception
Re: approveRequest returns false but still a command is created and executed [message #148094 is a reply to message #147379] Tue, 28 August 2007 09:48 Go to previous messageGo to next message
I set a breakpoint in SubProgressMonitor.java:155 but this had already
stalled my system due to the enourmous stack trace that has already been
produced. It seems like an enormous repetion of the same 6 lines:
Thread [main] (Suspended (breakpoint at line 155 in SubProgressMonitor))
SubProgressMonitor.internalWorked(double) line: 155
SubProgressMonitor(ProgressMonitorWrapper).internalWorked(do uble) line: 94
SubProgressMonitor.done() line: 139
AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,
IAdaptable) line: 242
AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,
IAdaptable) line: 137
DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor,IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(CompositeEMFOperation).doExecute(IProgr essMonitor,IAdaptable) line: 212 AbstractEditHelper$1(AbstractEMFOperation).execute(IProgress Monitor,IAdaptable) line: 137 DTNControlFlowCreateCommand(CreateElementCommand).doExecuteW ithResult(IProgressMonitor, IAdaptable) line: 84 DTNControlFlowCreateCommand.doExecuteWithResult(IProgressMon itor,IAdaptable) line: 119 DTNControlFlowCreateCommand(AbstractTransactionalCommand).do Execute(IProgressMonitor, IAdaptable) line: 246 DTNControlFlowCreateCommand(AbstractEMFOperation).execute(IP rogressMonitor,IAdaptable) line: 137 AbstractEditHelper$1(Compo
Re: approveRequest returns false but still a command is created and executed [message #148108 is a reply to message #147272] Tue, 28 August 2007 12:30 Go to previous messageGo to next message
What is the contract of approveRequest?
Meanwhile I created all XXXEditHelperAdvices I wanted and tried to use this
method to forbid the deletion of special kinds of nodes an edges. The method
returns the right values (fallse in every case I want to forbid deletion)
but this doesn't have any effect. I can still delete the element.
Is there any other way to disallow the creation/deletion of elements than
using approveRequest? What I want to achieve is forbidding the
createion/deletion of nodes and edges depending of the value of a certain
attribute in my nodes.
Greetings,
Alexander
"Alexander Dotor" <alexander.dotor@uni-bayreuth.de> schrieb im Newsbeitrag
news:faeroq$lnc$1@build.eclipse.org...
> Hello,
> I created a custom EditHelperAdvice and implemented my own approveRequest
> method. Depending on a value in the corresponding semantic model element
> it returns false. This works so far.
> I expected by implementing the approveRequest method to disallow the
> creation of links between two nodes. Wheneven the target node is marked as
> unchangeable it should be impossible to draw a link. I check the attribute
> in approveRequest and return false if the node is marked (i.e. the
> attribute is set).
> But even if approveRequest returns false a command is created an
> executed. After execution eclipse crashes with a stack overflow.
> Am I missing something or is this a bug?
> Greetings,
> Alexander Dotor
Re: approveRequest returns false but still a command is created and executed [message #149758 is a reply to message #148094] Mon, 10 September 2007 11:42 Go to previous messageGo to next message
Hello Alexander,
You can see the "tail" of StackTrace below. AFAIKSee you can put a breakpoint
into DTNControlFlowCreateCommand.doExecuteWithResult() and see the reason
of the loop in a debugger. BTW, are you using GMF 2.0?
line: 137
line: 212
line: 137
line: 119
line: 137
line: 212
line: 137
line: 119
line: 137
SemanticCreateCommand.doExecuteWithResult(IProgressMonitor, IAdaptable)line:
70
SemanticCreateCommand(AbstractCommand).execute(IProgressMoni tor,IAdaptable)
line: 134
CompositeCommand.doExecuteWithResult(IProgressMonitor, IAdaptable) line:406
CompositeCommand(AbstractCommand).execute(IProgressMonitor, IAdaptable)line:
134
134
DefaultOperationHistory.execute(IUndoableOperation, IProgressMonitor,IAdaptable)
line: 511
DiagramCommandStack.execute(ICommand, IProgressMonitor) line: 205
DiagramCommandStack.execute(Command, IProgressMonitor) line: 168
DiagramCommandStack.execute(Command) line: 155
UnspecifiedTypeConnectionTool(AbstractTool).executeCommand(C ommand) line:388
UnspecifiedTypeConnectionTool(AbstractTool).executeCurrentCo mmand() line:400
UnspecifiedTypeConnectionTool(ConnectionCreationTool).handle CreateConnection()
line: 346
UnspecifiedTypeConnectionTool(ConnectionCreationTool).handle ButtonUp(int)line:
183
UnspecifiedTypeConnectionTool(AbstractTool).mouseUp(MouseEve nt,EditPartViewer)
line: 1053
DiagramEditDomain(EditDomain).mouseUp(MouseEvent, EditPartViewer) line: 259
DomainEventDispatcher.dispatchMouseReleased(MouseEvent) line: 374
LightweightSystem$EventHandler.mouseUp(MouseEvent) line: 538
TypedListener.handleEvent(Event) line: 206
EventTable.sendEvent(Event) line: 66
FigureCanvas(Widget).sendEvent(Event) line: 938
Display.runDeferredEvents() line: 3682
Display.readAndDispatch() line: 3293
Workbench.runEventLoop(Window$IExceptionHandler, Display) line: 2389
Workbench.runUI() line: 2353
Workbench.access$4(Workbench) line: 2219
Workbench$4.run() line: 466
Realm.runWithDefault(Realm, Runnable) line: 289
Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 461
PlatformUI.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 149
IDEApplication.start(IApplicationContext) line: 106
EclipseAppHandle.run(Object) line: 153
EclipseAppLauncher.runApplication(Object) line: 106
EclipseAppLauncher.start(Object) line: 76
EclipseStarter.run(Object) line: 363
EclipseStarter.run(String[], Runnable) line: 176
NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: notavailable
[native method]
NativeMethodAccessorImpl.invoke(Object, Object[]) line: 39
DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: 25
Method.invoke(Object, Object...) line: 597
Main.invokeFramework(String[], URL[]) line: 504
Main.basicRun(String[]) line: 443
Main.run(String[]) line: 1169
Main.main(String[]) line: 1144
Alex Shatalin
Re: approveRequest returns false but still a command is created and executed [message #151922 is a reply to message #149758] Fri, 21 September 2007 06:09 Go to previous messageGo to next message
Yes, I'm using GMF 2.0. Thank you for the hint I'll have a look at it in
the debugger.
Alexander
Re: approveRequest returns false but still a command is created and executed [message #151958 is a reply to message #149758] Fri, 21 September 2007 08:30 Go to previous message
Hi Alex,
I found the error. I used a subclass of AbstractCommandRequest to access the
edited element and delivered true if a request of another type was passed to
the approveRequest-method. So it happended that every ConfigureRequest was
approved. The line
ICommand configureCommand =
elementType.getEditCommand(configureRequest);
returned another instance of the DTNControlFlowCreateCommand which was
executed again. I access the edited element now via getElementsToEdit() of
IEditCommandRequest and it runs without overflow.
But what puzzels me - the disapproval has absolutely no effect. I expected
that no control flow would be created now. But it runs as if no "false" has
been returned.
Alexander
"Alex Shatalin" <vano@borland.com> schrieb im Newsbeitrag
news:3c3172e617d458c9c1f183b5335b@news.eclipse.org...
> Hello Alexander,
> breakpoint into DTNControlFlowCreateCommand.doExecuteWithResult() and see
> the reason of the loop in a debugger. BTW, are you using GMF 2.0?
> line: 137
> line: 212
> line: 137
> line: 119
> line: 137
> line: 212
> line: 137
> line: 119
> line: 137 SemanticCreateCommand.doExecuteWithResult(IProgressMonitor,
> IAdaptable)line: 70
> line: 134 CompositeCommand.doExecuteWithResult(IProgressMonitor,
> IAdaptable)line: 134
> line:406 CompositeCommand(AbstractCommand).execute(IProgressMonitor,
> IAdaptable)line: 134 DefaultOperationHistory.execute(IUndoableOperation,
> IProgressMonitor,IAdaptable) line: 511
> line:388
> line:400
> line: 346
> 183
> line: 1053 DiagramEditDomain(EditDomain).mouseUp(MouseEvent,
> TypedListener.handleEvent(Event) line: 206 EventTable.sendEvent(Event)
> line: 66 FigureCanvas(Widget).sendEvent(Event) line: 938
> Display.runDeferredEvents() line: 3682 Display.readAndDispatch() line:
> 3293 Workbench.runEventLoop(Window$IExceptionHandler, Display) line: 2389
> Workbench.runUI() line: 2353 Workbench.access$4(Workbench) line: 2219
> Workbench$4.run() line: 466 Realm.runWithDefault(Realm, Runnable) line:
> 289 Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 461
> EclipseAppLauncher.start(Object) line: 76 EclipseStarter.run(Object) line:
> 363 EclipseStarter.run(String[], Runnable) line: 176
> notavailable [native method] NativeMethodAccessorImpl.invoke(Object,
> Object[]) line: 39 DelegatingMethodAccessorImpl.invoke(Object, Object[])
> line: 25 Method.invoke(Object, Object...) line: 597
> Main.invokeFramework(String[], URL[]) line: 504 Main.basicRun(String[])
> line: 443 Main.run(String[]) line: 1169 Main.main(String[]) line: 1144
> Alex Shatalin
Previous Topic:External label closer to object
Next Topic:remove notaion view from diagram
Current Time: Sun Jul 27 11:03:19 EDT 2025
Powered by FUDForum. Page generated in 0.03873 seconds
