Home » Modeling » GMF (Graphical Modeling Framework) » Automatic update of gmfmap when gmfgraph or gmftool are changed
Automatic update of gmfmap when gmfgraph or gmftool are changed [message #147190] Tue, 21 August 2007 03:05 Go to next message
Originally posted by: marsha.rohrer.swisscom.com
I'm new to GMF and I first experiented with GMF 1...but now I changed to
GMF 2.0 and I discovered a little inconvenient, or I don't get how to do
it.
With GMF 1 when I changed the gmfgraph or the gmftool the related gmfmap
was updated automatically. Now with GMF 2.0 this is not the case. So every
time when I change the gmfgraph or the gmftool I have to delete the
existing gmfmap and generate a new one...
Is this a bug, or don't I understand how the gmfmap can be reloaded.
Because when creating the gmfmap I give the relationship to the gmpgraph
and the gmftool, so it should be possible no?
Thanks for your help.
Marsha
Re: Automatic update of gmfmap when gmfgraph or gmftool are changed [message #147208 is a reply to message #147190] Tue, 21 August 2007 03:20 Go to previous messageGo to next message
It's not necessary to delete every time the gmfmap. You can modify it
without delete it firstly.
Sometimes, when you change something into the gmftool or gmfgraph, the
changes doesn't appears reflected into the gmfmap until you don't close
this file and reopen it. Try it, I thing it could be the "problem".
Marc.
Re: Automatic update of gmfmap when gmfgraph or gmftool are changed [message #147216 is a reply to message #147208] Tue, 21 August 2007 04:00 Go to previous message
Thanks a lot Marc. That was the "problem".
Previous Topic:Context Menus on Diagram
Next Topic:dynamic templates (xpt)
Current Time: Sun Jul 13 00:00:28 EDT 2025
Powered by FUDForum. Page generated in 0.28605 seconds
