Home » Language IDEs » ServerTools (WTP) » tomcat v5.5 server starting problem
tomcat v5.5 server starting problem [message #147007] Mon, 14 November 2005 18:42 Go to next message
Originally posted by: cvannouh.bea.com
I'm trying to publish my Dynamic Web Project to a server, Tomcat 5.5 and
when I try I get the some what cryptic error dialog:
Could not publish to the server.
Path must include project and resource name: /MyWebApp
I'm using Eclipse 3.1.1. I'm not sure what path is a problem so I'm not
quite sure where to go with this.
Re: tomcat v5.5 server starting problem [message #147099 is a reply to message #147007] Tue, 15 November 2005 09:56 Go to previous message
I believe this complaint is coming from within core Eclipse where
something that was expecting a path to a resource (i.e. a file within a
project) was handed a path to a project. Unfortunately, it's not clear
what is providing the incorrect path.
It's hard to tell whether the problem is in the project or the server.
If you create a new server and a new web project, can you publish the
new project to the new web server? If so, try different combinations
with you existing server and project to see what works and what doesn't.
Larry
Previous Topic:If I use WTP, do I need using struts?
Next Topic:Problem: How to synchornize
Current Time: Sun Jul 27 06:46:07 EDT 2025
Powered by FUDForum. Page generated in 0.03730 seconds
