Home » Archived » Maven Integration (M2E) » Is m2eclipse use archetype:generate to create project ?
Is m2eclipse use archetype:generate to create project ? [message #13687] Fri, 01 August 2008 13:00 Go to next message
Originally posted by: chingyichan.tw.gmail.com
I make an archetype plugin.
when I use maven in command line my resources file will locate as
package structure with archetype:generate but archetype:create will not.
I test it in eclipse with m2e plugin, files in the resources are all in
the root directory of resources. how do I make it locate as package
structure ?
Re: Is m2eclipse use archetype:generate to create project ? [message #13729 is a reply to message #13687] Fri, 01 August 2008 17:23 Go to previous message
m2eclipse actually is not calling either of those goals. It is directly
working with archetype-common component.
Please report issue about resources to the Archetype project at
http://jira.codehaus.org/browse/ARCHETYPE
regards,
Eugene
chingyichan wrote:
> I make an archetype plugin. when I use maven in command line my
> resources file will locate as package structure with
> in the root directory of resources. how do I make it locate as
> package structure ?
Previous Topic:How to add Eclipse marker on file when Maven build failed ?
Next Topic:stable dev build 0.9.6.20080731-1407 is published
Current Time: Sat Jul 26 19:33:25 EDT 2025
Powered by FUDForum. Page generated in 0.03075 seconds
