Home » Newcomers » Newcomers » how to set memory size when run app in eclipse
how to set memory size when run app in eclipse [message #146937] Wed, 05 April 2006 22:24 Go to next message
Re: how to set memory size when run app in eclipse [message #146945 is a reply to message #146937] Thu, 06 April 2006 05:55 Go to previous messageGo to next message
Originally posted by: daniel.megert.eclipse.org
http://wiki.eclipse.org/index.php/FAQ_How_do_I_increase_the_ heap_size_available_to_Eclipse%3F
Re: how to set memory size when run app in eclipse [message #147092 is a reply to message #146937] Thu, 06 April 2006 18:26 Go to previous message
Originally posted by: eclipse3.rizzoweb.com
When you launch your application in Eclipse, it is using a Launch
Configuration. You can edit Launch Configurations and change, among
other things, the VM options.
Search the Eclipse Help for "Launch Configurations" for all the details,
and be sure to read the Getting Started Guides in the Help - they would
answer a lot of these newbie questions.
Hope this helps,
Eric
Previous Topic:Automatic java compiling
Next Topic:Using an external package/class files
Current Time: Fri Jul 18 00:30:04 EDT 2025
Powered by FUDForum. Page generated in 0.11967 seconds
