Home » Language IDEs » ServerTools (WTP) » If I use WTP, do I need using struts?
If I use WTP, do I need using struts? [message #146933] Mon, 14 November 2005 10:31 Go to next message
When I use the WTP to create a web-application, the wtp will generate the
web.xml file automatically. Is it the same/similar as/to struts?
Re: If I use WTP, do I need using struts? [message #147075 is a reply to message #146933] Tue, 15 November 2005 05:05 Go to previous message
Originally posted by: gael.billard.jwaretechnologies.com
No. I'm using WTP for struts projects and for simple web application
projects (without struts).
The web.xml file is the web application configuration file. Struts
define some entries in this file but it is not a "struts config file".
> the web.xml file automatically. Is it the same/similar as/to struts?
Previous Topic:How do I insert templates in the XML editor?
Next Topic:tomcat v5.5 server starting problem
Current Time: Sun Oct 12 19:38:01 EDT 2025
Powered by FUDForum. Page generated in 0.03983 seconds
