Home » Language IDEs » ServerTools (WTP) » Eclipse 3.2M3 + latest WTP I build -- .wtpmodule gone the way of the dodo bird?
Eclipse 3.2M3 + latest WTP I build -- .wtpmodule gone the way of the dodo bird? [message #146835] Fri, 11 November 2005 09:03 Go to next message
Again a bleeding edge observation...
It seems that combos of Eclipse + WTP after 3.2M1 Eclipse + 1.0M8 Webtools
expect/generate a very different project configuration.
Here's what I've noticed...
..wtpmodule which used to live in the root of each project now lives in a
..settings directory and is now known as .component .
The xml syntax that used to define if the project was a jst.web or
jst.utility is removed from .component (formerly .wtpmodule). This syntax
now seems to live in a file called
org.eclipse.wst.common.project.facet.core.xml which also lives in the
..settings directory.
The .project file's buildSpec and natures encapsultate at a minimum the
following
<buildSpec>
<buildCommand>
<name>org.eclipse.jdt.core.javabuilder</name>
<arguments>
</arguments>
</buildCommand>
<buildCommand>
<name>org.eclipse.wst.validation.validationbuilder</name>
<arguments>
</arguments>
</buildCommand>
</buildSpec>
<natures>
<nature>org.eclipse.wst.common.project.facet.core.nature</nature >
<nature>org.eclipse.jdt.core.javanature</nature>
<nature>org.eclipse.wst.common.modulecore.ModuleCoreNature</nature >
<nature>org.eclipse.jem.workbench.JavaEMFNature</nature>
</natures>
Just wondering where I (and others) could find more info on the
changes/enhancements to Webtools web and utility project configuration? A
bug # or a link would suffice.
Chris.
Re: Eclipse 3.2M3 + latest WTP I build -- .wtpmodule gone the way of the dodo bird? [message #146848 is a reply to message #146835] Sat, 12 November 2005 19:12 Go to previous message
> following
> <buildSpec>
> <buildCommand>
> <arguments>
> </arguments>
> </buildCommand>
> <buildCommand>
> <arguments>
> </arguments>
> </buildCommand>
> </buildSpec>
> <natures>
> </natures>
> Chris.
The rename of the .wtpmodules file to .component was make the file name
more meaningful with its contents. The move of this file to the .setting
s folder was to consolidate meta-data files of a project as this folder
already has the .preference file.
The move of the project type and module version to the
org.eclipse.wst.common.project.facet.core.xml is due to the introduction
of facets that define the project type and version. The details of
facets and their design can be found here
The following design page is out-of-date currently will be updated in
the in the coming week:
http://www.eclipse.org/webtools/development/proposals/Featur es%20Framework%20Specification.htm
Also, the following document describes which facets are currently defined
in WTP:
http://www.eclipse.org/webtools/development/proposals/WtpPro jectFacets.html
- Vijay
Previous Topic:Strange error message
Next Topic:Why I couldn't find the J2EE perspective?
Current Time: Mon Jul 21 20:02:40 EDT 2025
Powered by FUDForum. Page generated in 0.03443 seconds
