Home » Eclipse Projects » GEF » text control creation on key press event
text control creation on key press event [message #146721] Fri, 06 August 2004 05:44 Go to next message
Originally posted by: david_michonneau.hotmail.com
I would like to create a GEF editor where you could create text control on
demand whenever the user starts typing inside the editor. The layout would
be a flow layout, and you would see the cursor blinking with the mouse like
in the flowcontainer of the logic example when you drag'n'drop a control in
it.
David
Re: text control creation on key press event [message #146751 is a reply to message #146721] Fri, 06 August 2004 11:44 Go to previous messageGo to next message
This is a 3.1 line item for GEF. We would like to start supporting Text
entry directly into graphical views. Currently this is not easy.
"David Michonneau" <david_michonneau@hotmail.com> wrote in message
news:cevjs2$ukc$1@eclipse.org...
So you could insert a native text box when the first key is pressed, and
allow entry into the native text box using direct edit techniques.
like
in
I didn't understand this part.
Re: text control creation on key press event [message #146761 is a reply to message #146751] Fri, 06 August 2004 13:07 Go to previous message
What do you mean by 3.1 line item? Will it be available in GEF version 3.1?
Can you give me some hints on how to get started?
> > Hi,
on
would
Yes, exactly.
> like
> in
I just meant you will see the blinking cursor all the time, and you can move
it around like in a text editor. In the logic example, there is a
flowcontainer control, when you drag something into it, you also see a
cursor telling you where the item will be dropped. So the goal is too see
such a cursor all the time, and the editor layout will be a flow layout
(like inside the flowcontainer).
David
Previous Topic:ResourceSelectionDialog
Next Topic:notify editor
Current Time: Mon Jul 14 02:17:37 EDT 2025
Powered by FUDForum. Page generated in 0.05253 seconds
