Home » Eclipse Projects » GEF » MultiLineLabel parent Composite from Draw2D Panel?
MultiLineLabel parent Composite from Draw2D Panel? [message #146682] |
Thu, 05 August 2004 21:26  |
I need to display, on a Draw2D canvas, several org.eclipse.draw2d.Panel
objects each containing a variety of IFigure objects plus one or more
org.eclipse.draw2d.widgets.MultiLineLabel objects. I shall be grateful if
someone could tell me what I am supposed to use as parent
org.eclipse.swt.widgets.Composite objects for each MultiLineLabel. Thanks.
Jeff
Re: MultiLineLabel parent Composite from Draw2D Panel? [message #146757 is a reply to message #146745] |
Fri, 06 August 2004 12:52   |
Hi Randy,
Thanks. I really want to use org.eclipse.ui.forms.widgets.* within Draw2D
Panels, I just thought that referencing MultiLineLabel was a more
legitimate way to get it!
I've tried using ImageFigures the way that VEP does but I have a lot of
nested panels and many controls and it runs far too slow and looks awful
when temporary dialogs pop-up to render the imagery (there's a maimum size
issue too, though I was thinking about double-buffering, etc. but this is
approach is just not practical for me).
I am experimenting with FigureCanvas, maybe using it directly to add
org.eclipse.ui.forms.widgets.* children or via an intermediary Composite
that uses a custom layout manager. Either way, I am happy that the 'flat'
bunch of org.eclipse.ui.forms.widgets.* in the presentation will just map
to my model hierarchy and I will be able to deal with repositioning,
resizing, etc., albeit with some coordinate transformation.
I'll let you know how I get on but if you know of any show-stopper reasons
why this approach absolutely won't work or if you have any other
suggestions I'd be grateful to know.
Warmest regards,
Jeff
Randy Hudson wrote:
> MultiLineLabel is just a convenience class for creating a PageFlow and a
> TextFlow figure. If you want to compose multiline text inside other
> figures, just use the text figures directly.
> "Jeff Lawson" <jeff@cogentlogic.com> wrote in message
> news:ceumnh$m8p$1@eclipse.org...
> > Hi
> > Jeff
Re: MultiLineLabel parent Composite from Draw2D Panel? [message #146774 is a reply to message #146757] |
Fri, 06 August 2004 13:44   |
So, you want to mix the flat look&feel native controls inside a
graphicalviewer? So you want some native controls. What else do you want
that's making you use GEF? i.e. dragging around the controls. What are you
building?
news:cf0cvi$9tb$1@eclipse.org...
> Hi Randy,
> Warmest regards,
> Jeff
> > > Hi
if
Thanks.
> > > Jeff
Re: MultiLineLabel parent Composite from Draw2D Panel? [message #146777 is a reply to message #146774] |
Fri, 06 August 2004 13:56   |
I'm developing a Forms-building application. There are very many complex
forms that I need to support and many more yet to be specified in a
re-usable system that needs to adapt to future requirements without more
ad hoc programming. Hence, the forms-builder tool.
I had originally anticipated writing the tool from scratch as a plug-in
until I saw GEF as a framework that integrates with Eclipse and provides
idioms that save me much work, such as the palette, properties, etc. I had
thought (briefly) of providing light-weight, IFigure-based
org.eclipse.ui.forms.widgets.* emulator classes but dismissed this as (i)
too much work and (ii) more work in the future if
org.eclipse.ui.forms.widgets.* is expanded.
> building?
> > Hi Randy,
> > Warmest regards,
> > Jeff
> > > > Hi
> if
> Thanks.
> > > > Jeff
Re: MultiLineLabel parent Composite from Draw2D Panel? [message #146790 is a reply to message #146777] |
Fri, 06 August 2004 15:48   |
Okay, org.eclipse.swt.widgets.Composite objects render perfectly fine on a
FigureCanvas but they occlude the repositon/resize handles. Rather than
spending ages trying to figure out how to reorder these layers, can you
please make a suggestion as this might be done?
you
> > building?
> > > Hi Randy,
size
reasons
> > > Warmest regards,
> > > Jeff
a
> > > > > Hi
grateful
> > if
> > Thanks.
> > > > > Jeff
Re: MultiLineLabel parent Composite from Draw2D Panel? [message #146814 is a reply to message #146790] |
Sun, 08 August 2004 16:29   |
So, SWT needs double-buffering (with ability to copy to Draw2D's buffer)
for this to work. Until then (if ever), emulation is necessary. Ah, well,
ever onwards!
Jeff
want
> you
> > > building?
> > > > Hi Randy,
Draw2D
awful
> size
is
Composite
'flat'
map
> reasons
> > > > Warmest regards,
> > > > Jeff
and
> a
> > > > > > Hi
more
> grateful
> > > if
> > > Thanks.
> > > > > > Jeff
Re: MultiLineLabel parent Composite from Draw2D Panel? [message #146888 is a reply to message #146790] |
Mon, 09 August 2004 11:03   |
You can place the handles further away from the composite, but that's about
it. If you need to nest things inside of each other, the handles cannot be
shown because they are lightweight and covered up by the outer composite.
You could create heavyweight handle :-(.
The VE project uses pictures of the real widgets withing GEF figures. That
way handles, dragging, etc. work, and you just update the pictures once the
changes are made.
news:cf0n9f$ojn$1@eclipse.org...
had
(i)
want
are
> you
> > > building?
> > > > Hi Randy,
Draw2D
of
awful
maimum
> size
this is
Composite
'flat'
just map
> reasons
> > > > Warmest regards,
> > > > Jeff
and
> a
other
> > > > > > Hi
more
> grateful
> > > if
MultiLineLabel.
> > > Thanks.
> > > > > > Jeff
Re: MultiLineLabel parent Composite from Draw2D Panel? [message #146961 is a reply to message #146888] |
Mon, 09 August 2004 14:17   |
Hi Randy, thanks for your response.
I found that the VE image-capture approach was easy to implement but,
because my forms require a lot of nesting, it was far too slow.
Furthermore, my outer panels, etc. are often larger that the display so
the clipped parts appear white (not drawn).
I cannot place handles further away than the composite because they would
still lie above other, containing composites (they would be confusing if
they were not occluded!).
Heavyweight handles...that's a good idea but the awkward part is in
handling the mouse events: composites swallow them up so the GEF/Draw2D
code won't work (unless they can somehow be re-routed). I find I spend far
too much time messing around with this sort of issue. Still, I didn't
think of heavyweight handles; I'm going to check this out!
Jeff
> changes are made.
> had
> (i)
> want
> are
> > you
> > > > building?
> > > > > Hi Randy,
> Draw2D
> of
> awful
> maimum
> > size
> this is
> Composite
> 'flat'
> just map
> > reasons
> > > > > Warmest regards,
> > > > > Jeff
> and
> > a
> other
> > > > > > > Hi
> more
> > grateful
> > > > if
> MultiLineLabel.
> > > > Thanks.
> > > > > > > Jeff
Re: MultiLineLabel parent Composite from Draw2D Panel? [message #146977 is a reply to message #146961] |
Mon, 09 August 2004 15:00   |
news:cf8f4m$3b1$1@eclipse.org...
For nesting, there is no reason to capture the nested controls. Just
capture the outer-most one, and everything else is a "glass pane" figure
which is just showing the parent's capture.
Yuck. I'm not sure what to do about that, other than move things around and
take multiple pictures :-(. But, if the panels are larger than the display,
then you probably only need to show a portion to the user which fits on the
display.
If you disable the native junk, you can still have figures/GEF which receive
the mouse events. So assuming you have figure's which are proxies to the
native forms stuff, you could have handles which are proxies to small
heavyweight controls. Proxy in this case is just synching up the placement
of the controls to match the figures. It's a real mess.
> Jeff
about
be
composite.
That
the
> > changes are made.
on a
than
you
complex
more
plug-in
provides
I
> > had
as
> > (i)
you
> > want
What
> > are
> > > you
> > > > > building?
> > > > > > Hi Randy,
within
> > Draw2D
more
lot
> > of
looks
> > awful
> > maimum
> > > size
but
> > this is
add
> > Composite
the
> > 'flat'
> > just map
repositioning,
show-stopper
> > > reasons
> > > > > > Warmest regards,
> > > > > > Jeff
PageFlow
> > and
> > > a
> > other
> > > > > > > > Hi
one or
> > more
be
> > > grateful
> > > > > if
> > MultiLineLabel.
> > > > > Thanks.
> > > > > > > > Jeff
Re: MultiLineLabel parent Composite from Draw2D Panel? [message #148285 is a reply to message #146977] |
Fri, 20 August 2004 15:46  |
Phew! That was a sod!
I now have SWT controls fully functioning within GEF.
I have a fully editable tree of SWT controls that sit on top an
identically positioned and sized tree of Draw2D panels.
To integrate with GEF, I needed to re-route SWT mouse events through to
the Draw2D panels. This required access to the LightweightSystem's
EventDispatcher, (in)accessible through the protected
getEventDispatcher(). So I extended LightweightSystem but then I needed to
install my LightweightSystem so I extended ScrollingGraphicalViewer to
override its createLightweightSystem().
All this was pretty straightforward (mouse coordinates need transforming,
of course).
One nasty problem required realizing that mouseEnter/mouseExit events
clear the drag tracker thereby thwarting mouse capture during a
resize/reposition operation.
I also had to mess around with resize imagery, e.g. overriding MoveHandle
so that it doesn't get drawn and moving the Draw2D handles so that they
partially lie under my SWT handles (that are internal to the bounds of SWT
controls).
The most difficult part was synchronizing the SWT locations to the Draw2D
locations and the model: different object-relative coordinates within a
scrolling view.
I'm left thinking that there are far too many protected methods and final
classes in the Eclipse APIs. Nonetheless, as I have always found in the
past, brute-force determination will eventually lead to working code. As
Ive mentioned this before: the Eclipse plug-in development documentation
is an order of magnitude too thin. Non-trivial plug-in development would
be impossible without the source code. Unfortunately, the good OOD
abstractions obfuscate too much!
Thanks to all Eclipse developers for continuing to work on such a powerful
system.
Jeff
> display.
> > Jeff
> about
> be
> composite.
> That
> the
> > > changes are made.
> on a
> than
> you
> complex
> more
> plug-in
> provides
> I
> > > had
> as
> > > (i)
> you
> > > want
> What
> > > are
> > > > you
> > > > > > building?
> > > > > > > Hi Randy,
> within
> > > Draw2D
> more
> lot
> > > of
> looks
> > > awful
> > > maimum
> > > > size
> but
> > > this is
> add
> > > Composite
> the
> > > 'flat'
> > > just map
> repositioning,
> show-stopper
> > > > reasons
> > > > > > > Warmest regards,
> > > > > > > Jeff
> PageFlow
> > > and
> > > > a
> > > other
> > > > > > > > > Hi
> one or
> > > more
> be
> > > > grateful
> > > > > > if
> > > MultiLineLabel.
> > > > > > Thanks.
> > > > > > > > > Jeff
Current Time: Thu Jul 17 20:19:31 EDT 2025
Powered by FUDForum. Page generated in 0.54990 seconds
