Home » Eclipse Projects » GEF » notify editor
notify editor [message #146597] Thu, 05 August 2004 04:34 Go to next message
Originally posted by: penzhan8451.sina.com
when i chenged some objects's locations (these objects were in
graphical
editor) in program , how could i notity the content editpart and response
these changes ?
Thanks in advance.
Re: notify editor [message #146675 is a reply to message #146597] Thu, 05 August 2004 19:57 Go to previous messageGo to next message
Your EditPart should be notified when the location in the model changes.
Your EditPart can then revalidate the figure (which will cause a layout to
occur). If you are using constraints, then simply setting the layout
constraint on the parent EditPart will do the trick. This should already be
happening in refreshVisuals().
"PL Fisher " <penzhan8451@sina.com> wrote in message
news:cesrdu$pm2$1@eclipse.org...
> graphical
> these changes ?
> Thanks in advance.
Re: notify editor [message #146688 is a reply to message #146675] Thu, 05 August 2004 22:44 Go to previous messageGo to next message
Thanks Pratik !
That's good. But I encountered another problem. The graphical include
lines. The changes could be response completely util i refresh the screen
(Example: minisize,then maximum). why ?
Many thanks.
> > Hi,
> > graphical
> > these changes ?
> > Thanks in advance.
Re: notify editor [message #146779 is a reply to message #146688] Fri, 06 August 2004 14:06 Go to previous message
Hmm, not sure. Try invoking figure.repaint(). But this should already be
happening during revalidation if the location's changed.
news:ceurap$s5v$1@eclipse.org...
> Thanks Pratik !
> Many thanks.
to
already be
> > > Hi,
> > > graphical
response
> > > these changes ?
> > > Thanks in advance.
Previous Topic:text control creation on key press event
Next Topic:Is there any example on showing two graph in one editor?
Current Time: Mon Jul 14 01:00:55 EDT 2025
Powered by FUDForum. Page generated in 0.05077 seconds
