Home » Eclipse Projects » GEF » How can we select aTransparent Figure ?
How can we select aTransparent Figure ? [message #146589] Thu, 05 August 2004 04:29 Go to next message
Originally posted by: justinaruja.isletsystems.com
Hello All,
I make a figure transparent by setOpaque(false).
but I cann't select this figure.
Is it possible?
Justin
Re: How can we select aTransparent Figure ? [message #146628 is a reply to message #146589] Thu, 05 August 2004 10:21 Go to previous messageGo to next message
You can override containsPoint(x, y) to return true in the areas where the
figure *does* paint.
"Justin" <justinaruja@isletsystems.com> wrote in message
news:cesr5t$pb0$1@eclipse.org...
> Hello All,
> Is it possible?
> Regards
> Justin
Re: How can we select aTransparent Figure ? [message #146640 is a reply to message #146589] Thu, 05 August 2004 10:29 Go to previous messageGo to next message
Originally posted by: rlemaigr.ulb.ac.be
> Hello All,
> Is it possible?
Can you select it if you "setOpaque(true)" it ?
I suppose you have already tried it but who knows...just to be sure...
I believed that the opacity of a Figure has only to do with weither or n=
ot =
the
background is filled with the background color before painting the =
Figure...
assuming that, I don't see any reason the opacity of a Figure would have=
something to do with the selectability of its EditPart...
But as always I may be wrong...
r=E9gis
Re: How can we select aTransparent Figure ? [message #146711 is a reply to message #146640] Fri, 06 August 2004 03:06 Go to previous messageGo to next message
rlemaigr@ulb.ac.be wrote:
>> Hello All,
>> Is it possible?
I can select it, if I "setOpaque(true)"
> not the
> Figure...
> régis
Re: How can we select aTransparent Figure ? [message #146715 is a reply to message #146628] Fri, 06 August 2004 03:12 Go to previous messageGo to next message
I code like below in Figure java file
public boolean containsPoint(int x, int y) {
Rectangle clientArea = getClientArea();
if (((clientArea.x < x)&& (clientArea.x + clientArea.width > x))
&& ((clientArea.y < y)&& (clientArea.y + clientArea.height >
y)))
return true;
} else
return super.containsPoint(x, y );
But not working.
Am I Correct?
>>Hello All,
>> Is it possible?
>>Regards
>>Justin
Justin
Re: How can we select aTransparent Figure ? [message #146822 is a reply to message #146715] Sun, 08 August 2004 22:54 Go to previous messageGo to next message
Does you figure use a local coordinate system or zoom? getClientArea would
be the wrong method to call in that case, since its in the children's
coordinates. Otherwise I can't think of anything.
"Justin D'aruja" <justinaruja@isletsystems.com> wrote in message
news:cevau3$f3j$1@eclipse.org...
the
> y)))
> return true;
> } else
> But not working.
> Am I Correct?
> >>Hello All,
> >> Is it possible?
> >>Regards
> >>Justin
> Regards
> Justin
Re: How can we select aTransparent Figure ? [message #147464 is a reply to message #146822] Thu, 12 August 2004 02:18 Go to previous messageGo to next message
Hello Randy,
My Figure is using local coordinate system.
Justin
> the
>> y)))
>> return true;
>> } else
>> But not working.
>> Am I Correct?
>>>>Hello All,
>>>> Is it possible?
>>>>Regards
>>>>Justin
>>Regards
>>Justin
Re: How can we select aTransparent Figure ? [message #147596 is a reply to message #147464] Thu, 12 August 2004 11:09 Go to previous messageGo to next message
So the code is incorrect. You should use
getBounds().getCropped(getInsets()).contains(x, y);
news:cff1ua$a1q$1@eclipse.org...
> Hello Randy,
> Regards
> Justin
would
> > the
x))
> >> y)))
> >> return true;
> >> } else
> >> But not working.
> >> Am I Correct?
> >>>>Hello All,
> >>>> Is it possible?
> >>>>Regards
> >>>>Justin
> >>Regards
> >>Justin
Re: How can we select aTransparent Figure ? [message #147676 is a reply to message #147596] Mon, 16 August 2004 01:37 Go to previous message
Hello Randy.
It is working now.
Thanks a lot
Justin
> > Hello Randy,
> > Regards
> > Justin
> would
> > > the
> x))
> > >> y)))
> > >> return true;
> > >> } else
> > >> But not working.
> > >> Am I Correct?
> > >>>>Hello All,
> > >>>> Is it possible?
> > >>>>Regards
> > >>>>Justin
> > >>Regards
> > >>Justin
Previous Topic:Label to connector disappears
Next Topic:gef versin 3.0.0 compatibility
Current Time: Wed Jul 23 03:53:08 EDT 2025
Powered by FUDForum. Page generated in 0.31058 seconds
