Re: Open Declaration -> yes || Search Declaration -> no? [message #146929 is a reply to message #146736] |
Tue, 02 March 2004 10:25  |
Originally posted by: chrismo.clabs.org
Jerome Lanneluc wrote:
> Did you see my answer to your previous post? I think you're having problems
> with your build path. Try solving those first.
I did, sorry I didn't follow up. I'd checked build paths, did diffs on
the .project and .classfile files on the two machines, did a full binary
diff of the Eclipse installs (which normally has some differences, so I
could have missed something that matters), CLASSPATH env var comparisons ...
Anyway, I tried installing 3.0 M7 on the 'bad' machine and it magically
started working, using, AFAIK, the same .project/.classpath files and
same settings as before ... weird.
Chris
http://clabs.org
FUDForum. Page generated in 0.03799 seconds
