Home » Language IDEs » C / C++ IDE (CDT) » Enable tracing for CDT plug-in
Enable tracing for CDT plug-in [message #146581] Tue, 07 June 2005 11:44 Go to next message
I would like how to enable tracing for CDT plug-in ?
In particular, I would like to trace MI commands sent by CDT to the gdb
debugger.
Note that I made some trials.
I've tried to create a ".options" file that contains:
org.eclipse.cdt.debug.mi.core/debug=true
then launch eclipse with following arguments:
-debug "file:.options"
but it doesn't work.
Can someone help me ?
Jerome
Re: Enable tracing for CDT plug-in [message #146596 is a reply to message #146581] Tue, 07 June 2005 12:42 Go to previous messageGo to next message
Originally posted by: mikhailk.qnx.com
You should use the full path. Also, the "-debug" argument should be added
before VM-related arguments.
"Jerome Correnoz" <jerome.correnoz@st.com> wrote in message
news:298d4750b13921df28f50a6f15fe1c2a$1@www.eclipse.org...
> debugger.
> Thanks
> Jerome
Re: Enable tracing for CDT plug-in [message #146672 is a reply to message #146596] Thu, 09 June 2005 07:49 Go to previous messageGo to next message
Even if I use the full path and no VM arguments but it doesn't work...
Nevertheless, I have a cmd window that opens with trace such as:
"Debug options:
file:/D:/Eclipse-3.0.1-SDK/.options loaded"
So my ".options" file is loaded correctly but no MI traces.
Note that I use CDT 2.1.1.
Jerome
Re: Enable tracing for CDT plug-in [message #146679 is a reply to message #146672] Thu, 09 June 2005 08:04 Go to previous message
Originally posted by: mikhailkhod.rogers.com
Check if the file's path and name are correct. This line appears in the
console window regardless if the file exists or not. The common error on
Windows is that the file has an hidden extension, .txt for example.
We have been using this option since CDT 1.1 and it works fine.
news:30c285c3901c6b366e097671d0b82b72$1@www.eclipse.org...
> "Debug options:
> Jerome
Previous Topic:CDT 3.0 support HPUX/PA_RISC (and aCC compiler)
Next Topic:Microcontroller under eclipse
Current Time: Mon Jul 14 02:41:18 EDT 2025
Powered by FUDForum. Page generated in 0.05608 seconds
