Home » Language IDEs » ServerTools (WTP) » How to allow double click breakpoints in XML files 1.0M8 ???
How to allow double click breakpoints in XML files 1.0M8 ??? [message #146557] Tue, 08 November 2005 11:49 Go to next message
Im now using 1.0 M8 and extending StructuredTextEdtior, I want to disable
the double click for bookmarks and have double clicks toggle breakpoints. I
had this working in 0.7 by extending StructuredTextEditorXML before it went
away but cannot seem to get this in 1.0M8.
I was doing so by calling setAction(RulerDoubleClick, null); in
createPartControl and had an editorAction with ActionID = RulerDoubleClick.
No longer seems to work.
Any help is appreciated.
Brian Jakubik
Re: How to allow double click breakpoints in XML files 1.0M8 ??? [message #146578 is a reply to message #146557] Tue, 08 November 2005 15:16 Go to previous messageGo to next message
You could do it by subclassing the editor class and overriding the
createActions() method, but subclassing the editor's not recommended.
The double-click action for the ruler is set within the
StructuredTextEditor.computeAndSetDoubleClickAction() method to one
that uses our breakpoint provider mechanism. When a breakpoint
provider is found, double-click automatically toggles breakpoints.
Otherwise it'll set bookmarks. It's not API since we're not sure if
the platform will provide a way to set breakpoints in all editors,
but you can use the org.eclipse.wst.sse.ui.breakpoints extension
point to contribute an implementor of
org.eclipse.wst.sse.ui.internal.provisional.extensions.break point.IBreakpointProvider.
Check the org.eclipse.jst.jsp.ui plugin for an example
implementation or the org.eclipse.wst.xml.ui.tests plugin for a
simpler (although commented out) example.
- Nitin
Re: How to allow double click breakpoints in XML files 1.0M8 ??? [message #147137 is a reply to message #146578] Tue, 15 November 2005 14:44 Go to previous message
I have opened bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=116483 on
this issue.
Brian Jakubik
"Nitin Dahyabhai" <nitind@us.ibm.com> wrote in message
news:dkr137$ive$1@news.eclipse.org...
>> I had this working in 0.7 by extending StructuredTextEditorXML before it
>> went away but cannot seem to get this in 1.0M8.
>> RulerDoubleClick. No longer seems to work.
> StructuredTextEditor.computeAndSetDoubleClickAction() method to one that
> uses our breakpoint provider mechanism. When a breakpoint provider is
> found, double-click automatically toggles breakpoints. Otherwise it'll set
> bookmarks. It's not API since we're not sure if the platform will provide
> a way to set breakpoints in all editors, but you can use the
> org.eclipse.wst.sse.ui.breakpoints extension point to contribute an
> implementor of
> Check the org.eclipse.jst.jsp.ui plugin for an example implementation or
> the org.eclipse.wst.xml.ui.tests plugin for a simpler (although commented
> out) example.
> - Nitin
Previous Topic:Problem: How to synchornize
Next Topic:problems in creating dynamic web project
Current Time: Sat Jul 26 15:17:50 EDT 2025
Powered by FUDForum. Page generated in 0.05819 seconds
