Home » Language IDEs » C / C++ IDE (CDT) » Conflicting names
Conflicting names [message #146434] Thu, 02 June 2005 05:01 Go to next message
Originally posted by: bluesboys.-remove-this-hotmail.com
Hi Group
I'm using namespaces in my project, and have the following two classes
namespace A
class foo //Interface
namespace A
namespace B
class foo //Implementation
The compilation runs without problems, but Eclipse shows an error under
problems, that I have conflicting names. Is there somewhere I can tell
Eclipse that it is ok, or shut down this check?
Best Regards
S
Re: Conflicting names [message #146521 is a reply to message #146434] Sun, 05 June 2005 01:15 Go to previous messageGo to next message
Originally posted by: emiliano.lesende.gmail.com
Hansen wrote:
> Hi Group
> namespace A
> namespace A
> namespace B
> Best Regards
> Søren Hansen
It might be a problem with the parser. If you can please post the source
code that causes the problem.
Emiliano
Re: Conflicting names [message #146534 is a reply to message #146521] Mon, 06 June 2005 02:24 Go to previous messageGo to next message
"Emiliano Lesende" <emiliano.lesende@gmail.com> wrote in message
news:d7u1p9$6ar$2@news.eclipse.org...
> Hansen wrote:
>> Hi Group
>> namespace A
>> namespace A
>> namespace B
>> Best Regards
>> S
Re: Conflicting names [message #146541 is a reply to message #146534] Mon, 06 June 2005 12:11 Go to previous messageGo to next message
Originally posted by: simon.ou.edu
Hi Hansen...
> <<tramsportLayerInterface.hpp>>
> namespace communicationlayer
> class TransportLayer
> public:
> TransportLayer() {};
> ... (a number of virtual functions)
> <<transportLayer.hpp>>
> #include "TransportLayerInterface.hpp"
you are defining 'communicationlayer' namespace twice (above and below).
This is not allowed. Do you mean that you want to use the namespace
inside the new defined name space?
One possibility that you may want to consider the following... design
your classes with no name space. Just write normal code when defining
your classes and such. Now, when you implement them, then use namespaces.
namespace rs232
TransportLayer *tL = new TransportLayer();
main()
rs232::tL->init();
using namespace rs232
tL->yourCodeFunction();
and in this way you keep zero namespace corruption, which may be your
intended result after all.
Regards...
Miguel.
> namespace rs232
> class TransportLayer : public communicationlayer::TransportLayer
> public:
> TransportLayer(unsigned short comPort);
> ... (implementation of the virtual functions in transportLayerInterface.hpp)
> Best Regards
> Søren Hansen
Re: Conflicting names [message #146629 is a reply to message #146534] Wed, 08 June 2005 15:13 Go to previous messageGo to next message
Assuming the missing closing braces in transportLayerInterface.hpp is just a
typo, the idea is ok. Namespaces are allowed to be have their definitions
split up like that and both communicationlayers are the same namespace.
The problem marker is likely a bug with the parser. I don't know what
version of CDT you are using, but in the latest from cvs (soon to be CDT
3.0M7) I don't get a problem marker with this pattern.
-Andrew
"Hansen" <bluesboys@-remove-this-hotmail.com> wrote in message
news:d80q6t$juc$1@news.eclipse.org...
> public:
> namespace rs232
> public:
> Best Regards
> S
Re: Conflicting names [message #146660 is a reply to message #146629] Thu, 09 June 2005 01:19 Go to previous messageGo to next message
Hi Andrew...
Yes, you are right. Splitting namespace definitions does compile/work
alright (any simple example can show this). Thank you for making this
point clear.
Regards...
Miguel
> -Andrew
Re: Conflicting names [message #146666 is a reply to message #146629] Thu, 09 June 2005 02:41 Go to previous messageGo to next message
"Andrew Niefer" <aniefer@ca.ibm.com> wrote in message
news:d87fpv$rn3$1@news.eclipse.org...
> a
> definitions
I use the 3.1M6
-S
Re: Conflicting names [message #146978 is a reply to message #146666] Wed, 15 June 2005 13:54 Go to previous messageGo to next message
Originally posted by: devin_steffler.ca.ibm.com
3.1M6 must be the version of Eclipse that you are using. Do you know what
version of CDT you are using?
Devin
news:d88obd$2eb$1@news.eclipse.org...
just
> > a
> > definitions
> I use the 3.1M6
> -S
Re: Conflicting names [message #146984 is a reply to message #146978] Mon, 20 June 2005 10:18 Go to previous message
"Devin Steffler" <devin_steffler@ca.ibm.com> wrote in message
news:d96fsj$92p$5@news.eclipse.org...
> Devin
It is correct, I
Previous Topic:matching brace/bracket in C++ editor
Next Topic:Managed Make vs Makefile
Current Time: Wed Jul 23 01:19:08 EDT 2025
Powered by FUDForum. Page generated in 0.06844 seconds
