Home » Language IDEs » Java Development Tools (JDT) » 3.0M7 cvs passwords lost
3.0M7 cvs passwords lost [message #146412] Sun, 29 February 2004 19:58 Go to next message
If I switch from 3.0M6 to M7, attempts to perform extssh cvs operations
suddenly start prompting me for a password (message is "Authentication
error: Invalid username, password, host or repository"). If I switch
back to M6 these operations work fine with no password requested. I
don't know if the operations work correctly M7 as I am not 100% certain
that I have entered the correct cvs password.
The same problem occurs for me with the latest integration build -
I20040226.
Has anyone else experienced this? Is there perhaps a workaround?
Scott
Re: 3.0M7 cvs passwords lost [message #146439 is a reply to message #146412] Mon, 01 March 2004 04:19 Go to previous messageGo to next message
> I20040226.
Yep. In my case, re-typing the password solved the problem.
Thilo
Re: 3.0M7 cvs passwords lost [message #146447 is a reply to message #146439] Mon, 01 March 2004 04:41 Go to previous messageGo to next message
>>I20040226.
> Thilo
In that case I will seek to confirm or reset my cvs password.
Scott
Re: 3.0M7 cvs passwords lost [message #146494 is a reply to message #146412] Mon, 01 March 2004 07:03 Go to previous messageGo to next message
Originally posted by: manahan.NOSPAM.ca.ibm.com
I believe that in M6 the passwords/keyring were stored in the workspace.
In M7 they are stored in the instance data/configuration area. Part of
the work to decouple the workspace from the user preferences.
Peter
> I20040226.
> Scott
Re: 3.0M7 cvs passwords lost [message #150046 is a reply to message #146494] Sun, 21 March 2004 13:01 Go to previous message
Originally posted by: daniel.megert.gmx.net
> workspace. In M7 they are stored in the instance data/configuration
> area. Part of the work to decouple the workspace from the user
> preferences.
Correct.
Dani
> Peter
>> operations suddenly start prompting me for a password (message is
>> "Authentication error: Invalid username, password, host or
>> repository"). If I switch back to M6 these operations work fine with
>> no password requested. I don't know if the operations work correctly
>> M7 as I am not 100% certain that I have entered the correct cvs
>> password.
>> I20040226.
>> Scott
Previous Topic:Plugin to open file in eclipse java editor
Next Topic:Error: "A class file was not written. The project may be inconsistent, if so try refreshing thi
Current Time: Sun Jul 27 02:54:49 EDT 2025
Powered by FUDForum. Page generated in 0.17217 seconds
