Home » Language IDEs » ServerTools (WTP) » JSP code completion pluggability
JSP code completion pluggability [message #146407] Mon, 07 November 2005 09:10 Go to next message
Hi everyone
I want to add custom code assist for the tags contained it taglib. I would
like to add attribute completion proposals, nested element proposals, etc. I
guess, the JSF plugin out there would have the same needs so I expect that
this pluggability is already in place. I checked the latest CVS sources (in
a head branch) but didn't find that support there. Maybe I should look some
other way?
Eugene
Re: JSP code completion pluggability [message #146613 is a reply to message #146407] Tue, 08 November 2005 18:18 Go to previous messageGo to next message
> other way?
Currently, you should already provided with completions for the
attribute names and tag names defined in your tag library
descriptor. Child element proposals also draw from the tag
libraries you've referenced in your jsp file.
There's no framework for contributing further individual proposals
as of yet, though. It's something we might look into after 1.0.
- Nitin
Re: JSP code completion pluggability [message #146648 is a reply to message #146613] Wed, 09 November 2005 02:48 Go to previous message
"Nitin Dahyabhai" <nitind@us.ibm.com> wrote in message
news:dkrbnk$o4$1@news.eclipse.org...
>> would like to add attribute completion proposals, nested element
>> proposals, etc. I guess, the JSF plugin out there would have the same
>> needs so I expect that this pluggability is already in place. I checked
>> the latest CVS sources (in a head branch) but didn't find that support
>> there. Maybe I should look some other way?
> Currently, you should already provided with completions for the attribute
> names and tag names defined in your tag library descriptor. Child element
> proposals also draw from the tag libraries you've referenced in your jsp
> file.
> There's no framework for contributing further individual proposals as of
> - Nitin
TLD-driven completions are not enough in many cases (i.e. when attribute
value is a class name we would like to suggest the class names available).
Here comes another thing we would like to plug in - validation. Some
attributes are classnames, some are numeric - we would like to do these
validations too. Maybe I should submit enhancement request in Bugzilla?
Previous Topic:WebSphere 5.1 support
Next Topic:Latest Release (I20051105) Status info
Current Time: Mon Jul 21 20:03:28 EDT 2025
Powered by FUDForum. Page generated in 0.33521 seconds
