Home » Modeling » GMF (Graphical Modeling Framework) » Generation of copyright statements
Generation of copyright statements [message #146396] Mon, 13 August 2007 10:32 Go to next message
I wanted to add some copyright statements into my generated gmf editor sources.
Is there any possibility to do this? (Of course supported through GMF! ;))
In gmfgen the Gen Editor node has such a property to set a Copyright Text,
but I can see no effect after regeneration!?
Andreas
Re: Generation of copyright statements [message #146404 is a reply to message #146396] Mon, 13 August 2007 10:38 Go to previous messageGo to next message
Andreas,
JMerge will not modify an existing header comment on a file, so you need
to set your copyright before you generate the files or delete all the
files and regenerate them.
Andreas Werner wrote:
> sources.
> Text, but I can see no effect after regeneration!?
> Andreas
Re: Generation of copyright statements [message #146417 is a reply to message #146404] Mon, 13 August 2007 10:52 Go to previous messageGo to next message
Hello Ed,
But in my generated editor sources there are no header comments before the
package statement at all!
Or will the generated comment be applied right before the class statement?
By the way in EMF there is a comment generated before the package statement
containing a copyright statement, that is defined in the genmodel!
Andreas
> Andreas,
> need to set your copyright before you generate the files or delete all
> the files and regenerate them.
>> editor
>> sources.
>> GMF!
>> Andreas
Re: Generation of copyright statements [message #146423 is a reply to message #146417] Mon, 13 August 2007 11:06 Go to previous messageGo to next message
Andreas,
I see. I just assumed GMF worked the same way. I guess not...
> Hello Ed,
> the package statement at all!
> statement?
> statement containing a copyright statement, that is defined in the
> genmodel!
> Andreas
>> Andreas,
>>> Hi,
>>> editor
>>> sources.
>>> GMF!
>>> Andreas
Re: Generation of copyright statements [message #146489 is a reply to message #146396] Tue, 14 August 2007 05:20 Go to previous message
Originally posted by: 5d5.mail.ru
There is a dedicated property in gmfgen model -
GenEditorGenerator.copyrightText.
> sources.
> Andreas
Previous Topic:Usage of "connector popups"
Next Topic:Label offsets are ignored
Current Time: Sat Jul 26 18:36:18 EDT 2025
Powered by FUDForum. Page generated in 0.04071 seconds
