Home » Language IDEs » Java Development Tools (JDT) » HotSpot technology use
HotSpot technology use [message #146348] Sun, 29 February 2004 07:08 Go to next message
Originally posted by: pmdanger.yahoo.com
I have a problem with Java application...they are quite slow in GUI or
they use too much memory / CPU.
Someone from SUN team told me that HotSpot technology is done to avoid
this kind of problem.
It seems this technology is included in JRE since J2SE 1.4.1.
What i don't know is how to use this technology ?
Should i include a special librairy or use some particular options ?
or this technology is automatically used when you use J2SE version 1.4.1
or higher ?
a piece of example could be useful.
thanks in advance.
Maileen
Re: HotSpot technology use [message #146357 is a reply to message #146348] Sun, 29 February 2004 08:11 Go to previous message
Hi Maileen,
> or higher ?
The HotSpot technology is just (as far as I know) the JIT (just in time)
compiler + some other stuff. It is automatically switched on. Slow gui
and high memory is mostly not the fault of java. It just depends on your
computer and most likely the quality of the java-application.
You mal try to increase the available memory using the -mx (or -Xmx)
setting. Consider HotSpot as a marketing word describing a major
change in the JavaVM architecture. It is switched on by default but
the JIT compiler can also be disabled by on default which is sometimes
usefull when debugging. (but not that often).
To learn more look at:
http://java.sun.com/products/hotspot/docs/whitepaper/Java_Ho tspot_v1.4.1/Java_HSpot_WP_v1.4.1_1002_1.html#1
If the application is slow and uses a vast of memory (and you also gave
the VM all memory your computer can offer using the -mx parameter),
consider the application as slow. And also HotSpot can not save the
day for you because it is allready trying to.
Hope it helps,
Martin (Kersten)
Previous Topic:Shared Workspace between Windows and Linux
Next Topic:Project dependency confusion
Current Time: Tue Jul 22 14:48:25 EDT 2025
Powered by FUDForum. Page generated in 0.19812 seconds
