Home » Language IDEs » ServerTools (WTP) » wsdl2java not creating all objects
wsdl2java not creating all objects [message #146312] Fri, 04 November 2005 07:00
Originally posted by: lxs.bcs.org
It would appear that wsdl2java does not always create java classes for
definitions found in schema and wsdl.
I have created a schema and 5 wsdl files to define a rather basic series
of web service interactions. The intention being to use this to show WS
functionality.
Previously I used Eclipse wizards to generate the Java from these files.
This worked fine to start, but I wished to build against Axis 1.2RC3 and
so created an Ant build file. When this is executed the generated Java is
missing 3 classes (all the others are generated, including complex types).
All three are of simple type (not complex): one to represent non-negative
integers, the other 2 to wrap axis.Duration type. I copy below the output
from wsdl2java call from Ant build.
Can someone explain to me how to override this, so that the classes are
generated? (naturally I can email the wsdl and xsd).
Many thanks in advance!
/== NonNegativeDecimal ==/
Dims:
isOnlyLiteralReferenced: false
RefType: null
org.apache.axis.wsdl.symbolTable.DefinedType
QName:
{http://demo.gridprovenance.org/BakingSchema}NonNegativeDeci mal
isReferenced? true
Class: org.apache.axis.wsdl.symbolTable.DefinedType
Base?: true
Undefined?: false
isSimpleType? true
Node: <simpleType name="NonNegativeDecimal">
<restriction base="decimal">
<minInclusive value="0" />
</restriction>
</simpleType>
Dims:
RefType:
QName: {http://www.w3.org/2001/XMLSchema}decimal
isReferenced? true
Class: org.apache.axis.wsdl.symbolTable.BaseType
Base?: true
Undefined?: false
isSimpleType? false
Node: null
/== BeatTime ==/
Dims:
RefType: null
QName: {http://demo.gridprovenance.org/BakingSchema}BeatTime
isReferenced? true
Base?: true
Undefined?: false
isSimpleType? true
Node: <simpleType name="BeatTime">
<restriction base="duration" />
</simpleType>
Dims:
RefType:
QName: {http://www.w3.org/2001/XMLSchema}duration
isReferenced? true
Base?: true
Undefined?: false
isSimpleType? false
Node: null
/== BakeTime ==/
Dims:
RefType: null
QName: {http://demo.gridprovenance.org/BakingSchema}BakeTime
isReferenced? true
Base?: true
Undefined?: false
isSimpleType? true
Node: <simpleType name="BakeTime">
</simpleType>
Dims:
RefType:
isReferenced? true
Base?: true
Undefined?: false
isSimpleType? false
Node: null
Dims:
RefType: null
QName: {http://www.w3.org/2001/XMLSchema}float
isReferenced? true
Base?: true
Undefined?: false
isSimpleType? false
Node: null
/== END ==/
Previous Topic:Building a School Schedule Web Application problem
Next Topic:Building a School Schedule Web Application Solution
Current Time: Tue Jul 22 01:36:38 EDT 2025
Powered by FUDForum. Page generated in 0.04959 seconds
