Home » Modeling » GMF (Graphical Modeling Framework) » Control a connection appearance
Control a connection appearance [message #146295] Sun, 12 August 2007 12:27 Go to next message
Originally posted by: jorge.matos_.-gmail.com
Hello!
I'm doing a graphic plugin with GMF to make a fluxogram that represents a
programming language. One of the possible figures that an user can use is a
representation of a switch statement. And each switch can have multiple
cases.
The problem is that, for example, if a switch has 10 cases because the
connections are a strait line the graphic will look like a tree...
What I wanted to do is to pre-define the connections between the switch and
the various cases statments to have a specific look. Something like this:
This is suposed to be an example of a switch with 4 cases :)
Thanks in advance
Re: Control a connection appearance [message #146475 is a reply to message #146295] Tue, 14 August 2007 05:14 Go to previous messageGo to next message
Originally posted by: 5d5.mail.ru
It will be easier to represent it like this:
Jorge Matos wrote:
> Hello!
> cases.
> Thanks in advance
Re: Control a connection appearance [message #146912 is a reply to message #146475] Thu, 16 August 2007 20:42 Go to previous messageGo to next message
Thanks for your help, but i'm not understanding your idea... Can you explain
it better? If you have any doubt about what I want to do feel free to ask!
I think I will have to use edit policies to achieve those connections,
right?
"Dmitry Stadnik" <5d5@mail.ru> wrote in message
news:f9rroq$hv3$1@build.eclipse.org...
> Jorge Matos wrote:
>> Hello!
>> a representation of a switch statement. And each switch can have multiple
>> cases.
>> and the various cases statments to have a specific look. Something like
>> this:
>> Thanks in advance
Re: Control a connection appearance [message #146959 is a reply to message #146912] Fri, 17 August 2007 06:41 Go to previous messageGo to next message
I just mean that you could break multisegment connection in a number of
connections with intermediate node and this could simplify your diagram
editor.
> right?
>> Jorge Matos wrote:
>>> Hello!
>>> cases.
>>> this:
>>> Thanks in advance
Re: Control a connection appearance [message #147832 is a reply to message #146959] Sat, 25 August 2007 10:16 Go to previous message
Ok, thanks.
But what I want is to control the connections look, and to do that I will
have to work with edit policies, isn't?
----- Original Message -----
Newsgroups: eclipse.modeling.gmf
Sent: Friday, August 17, 2007 11:41 AM
Subject: Re: Control a connection appearance
>editor.
>> explain it better? If you have any doubt about what I want to do feel
>> free to ask!
>> right?
>>> Jorge Matos wrote:
>>>> Hello!
>>>> a programming language. One of the possible figures that an user can
>>>> use is a representation of a switch statement. And each switch can have
>>>> multiple cases.
>>>> this:
>>>> Thanks in advance
Previous Topic:Get the primary edit part
Next Topic:Problem with the second part of the Gmf tutorial
Current Time: Mon Jul 14 11:55:35 EDT 2025
Powered by FUDForum. Page generated in 0.05239 seconds
