Home » Language IDEs » Java Development Tools (JDT) » hot code replace exception
hot code replace exception [message #146234] Fri, 27 February 2004 16:16 Go to next message
Originally posted by: janefung.yahoo.com
What does this hot code replace exception mean?
java.lang.UnsupportedOperationException: Hierarchy change not implemented
When I tried hot code replace one class, it is ok. But if I try again, I
get this error. Thanks.
Jane
Re: hot code replace exception [message #146243 is a reply to message #146234] Fri, 27 February 2004 16:54 Go to previous message
This means that the changes you have attempted is not supported by the VM
you are using...the classfile(s) that were generated were not accepted by
the target VM.
Darins
"jane fung" <janefung@yahoo.com> wrote in message
news:c1oc2u$eio$1@eclipse.org...
> Jane
Previous Topic:Unhandled Exception In Eclipse
Next Topic:What is "Launch in Background"?
Current Time: Thu Jul 17 07:55:01 EDT 2025
Powered by FUDForum. Page generated in 0.06826 seconds
