Home » Modeling » OCL » Are OCL derivation constraints a test ?
Are OCL derivation constraints a test ? [message #13597] Tue, 20 March 2007 16:46 Go to next message
Originally posted by: maiera.de.ibm.com
I am trying ot understand the semantic difference between invariant
constraints and derivation constraints.
It is clear to me what invariant constraints are, they purely test a
condition and are free of any side-effects.
Derivation constraints could be understood in two ways:
1. As a test whether the property has the specified value at any time,
i.e. also completely side-effect free.
2. As a specification on how to compute the value of the property at any
time. I.e. an OCL engine could compute the property value at run-time.
This sounds interesting, but seems to be in conflict with the general
statement that OCL is side-effect free.
I tend to go for 1., but on the other hand that leaves derivatoin
constraints to be only a special case of invariants, so why ar ethey
needed at all.
-> Is there a simple answer how to understand derivation constraints ?
Andy
Re: Are OCL derivation constraints a test ? [message #13648 is a reply to message #13597] Wed, 21 March 2007 11:58 Go to previous messageGo to next message
Hi, Andy,
The answer, I think, is a blend of #1 and #2. The derivation constraint
specifies what the value of a derived property is, by providing an
expression whose value is the expected value of the property. In this
respect, it "constrains" the derived property.
At run-time, an implementation can make this (implicit) equality constraint
always trivially satisfied by actually evaluating the OCL expression. The
OCL expression, as such, is still side-effect-free. It does not change any
state of the object; remember that the property is, by definition, a
computed value.
Does that help?
Christian
> needed at all.
> Andy
Re: Are OCL derivation constraints a test ? [message #13692 is a reply to message #13648] Thu, 22 March 2007 03:22 Go to previous message
Christian,
that helps!
> The OCL expression, as such, is still side-effect-free.
That was the key for me to address my confusion about it.
Thanks!
Andy
Christian W. Damus wrote:
> Hi, Andy,
> computed value.
> Does that help?
> Christian
>> needed at all.
>> Andy
Previous Topic:Null exception in constraints on EnumerationLiteral
Next Topic:"self" context and context defined by "context" keyword
Current Time: Sun Aug 31 23:41:53 EDT 2025
Powered by FUDForum. Page generated in 0.06527 seconds
