Home » Archived » BIRT » Need help on using a filter in Total.count()
Need help on using a filter in Total.count() [message #146160] Mon, 20 March 2006 16:04 Go to next message
I'm trying to use a filter in the Total.count BIRT function but get errors
when I try to add something like row["statusCodes"]='A'. I don't see any
other way in the expression builder to add anything explicitly called a
filter. This is in a cell in a grid component. So far the only way I can
see to get around this is to use a seperate dataset with the filter set
there.
Basically I want to create something like the following:
Status Code Number of Records Percent of Total
A 10 13.5
B 12 16.2
C 5 6.8
D 43 58.1
E 24 32.4
Total 74
Any help would be appreciated.
Jim
Re: Need help on using a filter in Total.count() [message #146169 is a reply to message #146160] Mon, 20 March 2006 16:25 Go to previous messageGo to next message
Originally posted by: vladperl.semanticprogrammer.org
"Jim Norris" <james.norris@pb.com> wrote in message
news:dvn5co$veb$1@utils.eclipse.org...
> there.
> A 10 13.5
> B 12 16.2
> C 5 6.8
> D 43 58.1
> E 24 32.4
> Total 74
> Jim
Re: Need help on using a filter in Total.count() [message #146177 is a reply to message #146160] Mon, 20 March 2006 16:28 Go to previous messageGo to next message
> there.
try:
row["statusCodes"]=='A'
> A 10 13.5
> B 12 16.2
> C 5 6.8
> D 43 58.1
> E 24 32.4
> Total 74
I suppose is better to use group item to do this.
Re: Need help on using a filter in Total.count() [message #146431 is a reply to message #146177] Tue, 21 March 2006 07:40 Go to previous message
Thanks Vladimir,
That did the trick. This is another one of those 'duh' moments for me :-)
Jim
"Vladimir" <vladperl@semanticprogrammer.org> wrote in message
news:dvn6o7$9ia$1@utils.eclipse.org...
>> errors when I try to add something like row["statusCodes"]='A'. I don't
>> see any other way in the expression builder to add anything explicitly
>> called a filter. This is in a cell in a grid component. So far the only
>> way I can see to get around this is to use a seperate dataset with the
>> filter set there.
> try:
>> A 10
>> 13.5
>> B 12
>> 16.2
>> C 5
>> 6.8
>> D 43
>> 58.1
>> E 24
>> 32.4
>> Total 74
Previous Topic:internationalization
Next Topic:General question of design --> Reporting in a Three-Tier-Architecture with RMI
Current Time: Sat Jul 26 19:31:31 EDT 2025
Powered by FUDForum. Page generated in 0.05620 seconds
