Home » Archived » Visual Editor (VE) » VE Doesn't Install Into Galileo Packages
VE Doesn't Install Into Galileo Packages [message #146139] Wed, 08 July 2009 06:40 Go to next message
--------------020007060400040703000008
As others have reported, the dependencies for VE 1.4 make following the
instructions at
http://wiki.eclipse.org/VE/Update#Install_VE_1.4_into_Eclips e_3.5_.2F_Galileo
pretty much impossible.
Cannot complete the install because of a conflicting dependency.
Software being installed: Java EMF Model 1.4.0.HEAD-7H-FUF9Ypuea5
(org.eclipse.jem.feature.group 1.4.0.HEAD-7H-FUF9Ypuea5)
Software currently installed: Eclipse Modeling Tools
1.2.0.20090618-1854 (epp.package.modeling 1.2.0.20090618-1854)
Only one of the following can be installed at once:
Java EMF Model Utilities 2.0.300.HEAD (org.eclipse.jem.util
2.0.300.HEAD)
Java EMF Model Utilities 2.0.200.v200905140200
(org.eclipse.jem.util 2.0.200.v200905140200)
Cannot satisfy dependency:
To: org.eclipse.epp.package.modeling.feature.feature.group
[1.2.0.20090618-1854]
(org.eclipse.epp.package.modeling.feature.feature.group
To: org.eclipse.wst.xml_ui.feature.feature.group 0.0.0
To: org.eclipse.jem.util [2.0.300.HEAD]
From: WST Common Core 3.1.0.v200903021835-7B77FXTF7RZHITIwQkLs_V
(org.eclipse.wst.common_core.feature.feature.group
3.1.0.v200903021835-7B77FXTF7RZHITIwQkLs_V)
To: org.eclipse.jem.util [2.0.200.v200905140200]
3.1.0.v200903021835-7B5FREDhdMNPm7dkmBmpUJxRlMta
(org.eclipse.wst.common_ui.feature.feature.group
3.1.0.v200903021835-7B5FREDhdMNPm7dkmBmpUJxRlMta)
To: org.eclipse.wst.common_core.feature.feature.group
[3.1.0.v200903021835-7B77FXTF7RZHITIwQkLs_V]
3.1.0.v200905240756-7H6FMVDxtkM-5OgPGKK4xQocS5AL
(org.eclipse.wst.xml_ui.feature.feature.group
3.1.0.v200905240756-7H6FMVDxtkM-5OgPGKK4xQocS5AL)
To: org.eclipse.wst.common_ui.feature.feature.group
[3.1.0.v200903021835-7B5FREDhdMNPm7dkmBmpUJxRlMta]
Are any VE committers monitoring this newsgroup? Is there any chance
that a version of VE that actually works with the Galileo versions of
WTP and EMF can be produced? Are there hard upper bounds on versions
that are really necessary?
Ed
<html>
<head>
</head>
instructions at <a
href=" http://wiki.eclipse.org/VE/Update#Install_VE_1.4_into_Eclips e_3.5_.2F_Galileo"> http://wiki.eclipse.org/VE/Update#Install_VE_1.4_into_Eclips e_3.5_.2F_Galileo</a>
pretty much impossible.<br>
<blockquote>Cannot complete the install because of a conflicting
dependency.<br>
&nbsp; Software being installed: Java EMF Model 1.4.0.HEAD-7H-FUF9Ypuea5
(org.eclipse.jem.feature.group 1.4.0.HEAD-7H-FUF9Ypuea5)<br>
&nbsp; Software currently installed: Eclipse Modeling Tools
1.2.0.20090618-1854 (epp.package.modeling 1.2.0.20090618-1854)<br>
&nbsp; Only one of the following can be installed at once: <br>
&nbsp;&nbsp;&nbsp; Java EMF Model Utilities 2.0.300.HEAD (org.eclipse.jem.util
2.0.300.HEAD)<br>
&nbsp;&nbsp;&nbsp; Java EMF Model Utilities 2.0.200.v200905140200
(org.eclipse.jem.util 2.0.200.v200905140200)<br>
&nbsp; Cannot satisfy dependency:<br>
&nbsp;&nbsp;&nbsp; From: Eclipse Modeling Tools 1.2.0.20090618-1854
&nbsp;&nbsp;&nbsp; To: org.eclipse.epp.package.modeling.feature.feature.group
[1.2.0.20090618-1854]<br>
&nbsp;&nbsp;&nbsp; From: EPP Modeling Feature 1.2.0.20090618-1854
&nbsp;&nbsp;&nbsp; To: org.eclipse.wst.xml_ui.feature.feature.group 0.0.0<br>
&nbsp;&nbsp;&nbsp; From: Java EMF Model 1.4.0.HEAD-7H-FUF9Ypuea5
&nbsp;&nbsp;&nbsp; To: org.eclipse.jem.util [2.0.300.HEAD]<br>
&nbsp;&nbsp;&nbsp; From: WST Common Core 3.1.0.v200903021835-7B77FXTF7RZHITIwQkLs_V
3.1.0.v200903021835-7B77FXTF7RZHITIwQkLs_V)<br>
&nbsp;&nbsp;&nbsp; To: org.eclipse.jem.util [2.0.200.v200905140200]<br>
&nbsp;&nbsp;&nbsp; From: WST Common UI
3.1.0.v200903021835-7B5FREDhdMNPm7dkmBmpUJxRlMta)<br>
&nbsp;&nbsp;&nbsp; To: org.eclipse.wst.common_core.feature.feature.group
[3.1.0.v200903021835-7B77FXTF7RZHITIwQkLs_V]<br>
&nbsp;&nbsp;&nbsp; From: Eclipse XML Editors and Tools
3.1.0.v200905240756-7H6FMVDxtkM-5OgPGKK4xQocS5AL)<br>
&nbsp;&nbsp;&nbsp; To: org.eclipse.wst.common_ui.feature.feature.group
[3.1.0.v200903021835-7B5FREDhdMNPm7dkmBmpUJxRlMta]<br>
</blockquote>
Are any VE committers monitoring this newsgroup?&nbsp; Is there any chance
WTP and EMF can be produced?&nbsp; Are there hard upper bounds on versions
that are really necessary?<br>
<br>
Ed<br>
</body>
</html>
--------------020007060400040703000008--
Re: VE Doesn't Install Into Galileo Packages [message #468333 is a reply to message #146139] Wed, 05 August 2009 02:54 Go to previous messageGo to next message
Anyone solved this issue?\
I have the same problem.
Re: VE Doesn't Install Into Galileo Packages [message #468361 is a reply to message #468333] Wed, 05 August 2009 05:04 Go to previous messageGo to next message
yesterday I installed it in Galileo, using the VE update site... I had
to select only VE packages (the other 3 didn't work), and it installed...
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: VE Doesn't Install Into Galileo Packages [message #496448 is a reply to message #468361] Tue, 10 November 2009 02:23 Go to previous messageGo to next message
Is there a solution to this problem yet? I still seem to get the same problem as has been reported here when working with Galileo and VE1.4.0.
Roland
Re: VE Doesn't Install Into Galileo Packages [message #496940 is a reply to message #496448] Wed, 11 November 2009 14:38 Go to previous messageGo to next message
I have tested. It works. Please make sure you are not using a Firewall or
protected by a Network Firewall.
Best regards
Yves YANG
"Roland" <roland.goecke@gmail.com> wrote in message
news:hdb4dj$e3c$1@build.eclipse.org...
> Roland
Re: VE Doesn't Install Into Galileo Packages [message #496966 is a reply to message #496940] Wed, 11 November 2009 17:20 Go to previous messageGo to next message
This problem is the subject of Bugzilla report #290037. Everything works fine if you install into a base Eclipse version. However, if you choose to install into any package containing the Web Tools version of JEM/EMF, you will get the referenced error. I currently have 2 Eclipse installs to work-around the problem. The first is a base Eclipse package with VE 1.4.0 installed which I use for thick client development. The second is a J2EE Eclipse Package without VE installed. This work-around means separating my codebase into 2 different workspaces. I'd like to see this problem resolved soon so that I can return to a single install and workspace.
Re: VE Doesn't Install Into Galileo Packages [message #505513 is a reply to message #496966] Thu, 31 December 2009 10:40 Go to previous messageGo to next message
I have recently tried installing into three different Eclipse download versions (in Linux, annotated below), and neither the .zip archive nor the web site's packages even show up. I tried all three within the last two days.
I tried totally purging all references to eclipse including those hidden in my home directory.
Still can't get VE installed for some reason. I've tried:
Eclipse IDE for Java EE Developers (189 MB)
Eclipse IDE for Java Developers (92 MB)
and, last night:
Eclipse Classic 3.5.1 (162 MB)
I don't know what else to try. I'm using Linux Mint 8 (a Ubuntu Karmic derivative).
Kurt
Re: VE Doesn't Install Into Galileo Packages [message #506554 is a reply to message #505513] Thu, 07 January 2010 18:29 Go to previous messageGo to next message
You need just select one option VE SDK. If it still donest' work, make sure
there isn't a firewall.
Best regards
Yves YANG
"Kurt" <peterskurt@msn.com> wrote in message
news:hhiglp$34u$1@build.eclipse.org...
>days.
> and, last night:
> derivative).
> Kurt
Re: VE Doesn't Install Into Galileo Packages [message #506565 is a reply to message #506554] Thu, 07 January 2010 20:33 Go to previous messageGo to next message
No, there is no firewall set, and I used even the .zip file and it doesn't even READ anything to LET me select the VE. That's why I tried to clean everything.
Kurt
Re: VE Doesn't Install Into Galileo Packages [message #508218 is a reply to message #506565] Sun, 17 January 2010 13:24 Go to previous messageGo to next message
I've been struggling with this for a day or so and think I've come across the solution. It's file permissions. I noticed that VE installed correctly (after choosing only the VE/VE-SDK options) on my Windows XP machine but not on my Windows 7 machine. The Windows 7 machine produced all kinds of dependencies not met errors. I noticed that the Windows 7 installation was missing all the update sites that the XP installation had. I manually put them in and VE loaded but VE didn't appear anywhere. At first I was puzzled because the Update manager said it was installed but the Help files and the VE views were not there. I check against the XP machine and I discovered that all the plugin/feature files were missing on my Windows 7 machine.
Next I reinstalled eclipse in my User area and everything worked. I also reinstalled eclipse in C:\ and ran it as "administrator" and everything also worked. I'm not a Vista/Windows 7 expert so I'm not sure what's the best solution for this, but if eclipse can't write files in its area, then VE won't install correctly. I hope this helps.
John
Re: VE Doesn't Install Into Galileo Packages [message #509012 is a reply to message #496940] Thu, 21 January 2010 02:07 Go to previous messageGo to next message
Well, I still couldn't do it with Galileo, but it works fine with Ganymede now, so I will use that for the time being.
Roland
Re: VE Doesn't Install Into Galileo Packages [message #617395 is a reply to message #146139] Wed, 05 August 2009 02:54 Go to previous messageGo to next message
Re: VE Doesn't Install Into Galileo Packages [message #617396 is a reply to message #468333] Wed, 05 August 2009 05:04 Go to previous messageGo to next message
Re: VE Doesn't Install Into Galileo Packages [message #617448 is a reply to message #468361] Tue, 10 November 2009 02:23 Go to previous messageGo to next message
Roland
Re: VE Doesn't Install Into Galileo Packages [message #617472 is a reply to message #617448] Wed, 11 November 2009 14:38 Go to previous messageGo to next message
Best regards
Yves YANG
> Roland
Re: VE Doesn't Install Into Galileo Packages [message #617475 is a reply to message #496940] Wed, 11 November 2009 17:20 Go to previous messageGo to next message
Re: VE Doesn't Install Into Galileo Packages [message #617599 is a reply to message #617475] Thu, 31 December 2009 10:40 Go to previous messageGo to next message
and, last night:
Kurt
Re: VE Doesn't Install Into Galileo Packages [message #618350 is a reply to message #617599] Thu, 07 January 2010 18:29 Go to previous messageGo to next message
Best regards
Yves YANG
>days.
> and, last night:
> derivative).
> Kurt
Re: VE Doesn't Install Into Galileo Packages [message #618352 is a reply to message #506554] Thu, 07 January 2010 20:33 Go to previous messageGo to next message
Kurt
Re: VE Doesn't Install Into Galileo Packages [message #618357 is a reply to message #618352] Sun, 17 January 2010 13:24 Go to previous messageGo to next message
John
Re: VE Doesn't Install Into Galileo Packages [message #618358 is a reply to message #496940] Thu, 21 January 2010 02:07 Go to previous message
Roland
Previous Topic:Visual Editor hangs on eclipse restart.
Next Topic:Extending Visual Editor to generate XML instead of Java code
Current Time: Wed Jul 16 17:30:33 EDT 2025
Powered by FUDForum. Page generated in 0.08154 seconds
