Home » Eclipse Projects » Eclipse Platform » Bracket ('[') cursor in the editors
Bracket ('[') cursor in the editors [message #145829] Fri, 17 October 2003 10:57 Go to next message
Originally posted by: krishna.kolla.delta.com
Hello all, I am fairly new to the eclipse. I recently installed 3.0 and
started using it. However, I don't like the bracket cursor (the [) in the
java editors. How do I get rid of this ? is there any way to set a
particular cursor option ? Thanks for all your help.
Re: Bracket ('[') cursor in the editors [message #145864 is a reply to message #145829] Fri, 17 October 2003 11:47 Go to previous messageGo to next message
You are in smart insert mode.
Play with hitting the "Insert" key to change modes in the Java editor.
In the bottom right of the editor a message indicates the mode you are in.
HTH
Darins
"Krishna" <krishna.kolla@delta.com> wrote in message
news:bmp005$3a7$1@eclipse.org...
Re: Bracket ('[') cursor in the editors [message #145913 is a reply to message #145864] Fri, 17 October 2003 12:52 Go to previous messageGo to next message
Thanks. it worked. I guess it was not that obvious. All along I was trying
to find something in the preferences.
> HTH
> Darins
Re: Bracket ('[') cursor in the editors [message #146227 is a reply to message #145913] Sat, 18 October 2003 10:28 Go to previous messageGo to next message
Please not that when using Insert mode instead of Smart Insert mode you
will lose lots of smart typing support.
Dani
>>HTH
>>Darins
Re: Bracket ('[') cursor in the editors [message #149950 is a reply to message #146227] Mon, 27 October 2003 17:16 Go to previous messageGo to next message
Originally posted by: ed.burnette.REMOVE.THIS.sas.com
Is there any reason for 'dumb mode'? Why not just have smart mode and let it
use the regular I-beam cursor. You can always edit a Java file in the
regular text editor for the equivalent of 'dumb mode'.
Ed
"Daniel Megert" <daniel.megert@gmx.net> wrote in message
news:bmrik9$ouj$2@eclipse.org...
trying
> Dani
in.
Re: Bracket ('[') cursor in the editors [message #150055 is a reply to message #149950] Tue, 28 October 2003 04:58 Go to previous message
Add your comments/votes to bug 39205.
Dani
>Ed
>trying
>>Dani
>in.
Previous Topic:Can't import org.eclipse.core.resources to my plugin
Next Topic:Feature request
Current Time: Fri Jul 18 11:30:31 EDT 2025
Powered by FUDForum. Page generated in 0.04834 seconds
